Old 31-03-05, 07:55 AM   #1
MitchC
Default Neutral Indication Light?
Hey guys,
[ramble] Well I have run into a situation that I don't have the knowledge to fix but I thought you could help me out. I have found that my Neutral light is burnt out. Or seems that way. It's not that I am having a hard time finding neutral, I know all the tricks for that. I know I am in neutral because the bike is allowing me to easily roll it front and back. Also, when I used to pass from first to second, I could see it flash for a second and now it is not doing so. Is there something I can check? It seems as though a wire came loose? I did remove the linkage on the gear lever and perhaps there is a wire/sensor down there? Although, I have looked and there doesn't seem to be. Is it a LED that indicates neutral? Something that can be replaced... I am somewhat concerned. That light is quite handy, and on a bike that is tricky to find neutral sometimes, it would be tough without it. [/ramble]
Thanks for all your advice and help!!
Mitch
Old 31-03-05, 01:13 PM   #2
hall13uk
get down to your dealer explain the problem perhaps hes had the problem before.
sorry i cant be of more help
Old 31-03-05, 01:44 PM   #3
markfc
It's an led, not a bulb, so i can't see blowing or burning out in a couple of years.
You could easily check with a new led/multimeter but it's alot of work stipping the front end down to find out.
I'll see if you can multimeter it from under the under the seat.
otherwise, I'm not sure where the neutral light switch is, it's probably integrated in the ecu on k3+
Old 31-03-05, 04:39 PM   #4
MitchC
Hey guys,
Problem is, I am hundreds of miles from my dealer. I guess I will have to give them a call and see what they recommend.
Mitch
Old 01-04-05, 08:34 AM   #5
MitchC
Hey,
Well, if anyone runs into this problem I think, my father and I have realized what we did wrong. We put the linkage on upside down. I will verify this tomorrow so see if that's what was causing the issue... I sure hope that fixes everything...
Mitch
Old 01-04-05, 08:37 AM   #6
Stig
Thanks for the info Mitch, hope this was the problem and is now sorted. I had to run my bike with no speedo, tacho, instrument indication lights at all for a period of time, was a hindrance more than a problem.
Old 01-04-05, 08:15 PM   #7
MitchC
Hey,
Well, I realize now that I had it set up for racing... 1 up, 5 down. I didn't know you could do that... That's cool. Good that it's sorted.
Mitch
Neutral Light DarrenSV650S Bikes - Talk & Issues 3 09-05-09 05:12 PM
Neutral Light flicker Grinch SV Talk, Tuning & Tweaking 2 08-04-09 03:29 PM
Me being a numpty - no neutral light and fi light is on Whitehouse SV Talk, Tuning & Tweaking 8 03-04-09 03:50 PM
Intermittent Neutral Light mikebrooman SV Talk, Tuning & Tweaking 2 19-02-09 03:28 PM
False neutral light JediGoat Bikes - Talk & Issues 11 05-09-07 09:14 AM
