Old 22-02-09, 01:53 PM   #1
mikebrooman
Default Rear brake pad retaining pins.
Hi,
Currently have bike in bits.
Replacing rear pads + disk. I've got to the stage where I need to remove retaining pins, but they won't budge. Should they spin? is there an easy way to remove the pins? thanks
Old 22-02-09, 02:03 PM   #2
dirtydog
Knob faced knobster
dirtydog's Avatar
Default Re: rear break retainin pins
Should they spin? Yes but they wont because they'll be seized.
There's a few things you can try to get them out. It's been covered loads of times on here, try the search function
2011 Speed Triple 1050
Old 22-02-09, 02:18 PM   #3
mikebrooman
is there any way of getting the pins out without splittling the caliper???
Old 22-02-09, 03:17 PM   #4
dirtydog
Knob faced knobster
dirtydog's Avatar
you could try mole grips to try and twist them but they're likely to be knackered afterwards (the pins not the grips). I did this before and got 1 pin out, the other snapped
Old 22-02-09, 03:41 PM   #5
svrich
I used a small blow torch (chefs sized one), some 3-in-1 oil, and a stud extractor set.
Heat the caliper around the pins (be careful!), very carefully apply the oil (avoiding any braking surfaces) to the pins where they go into the caliper. Repeat a couple of times. Use the stud extractor set to rotate the pins and pull back as you do so. If they don't budge, repeat the first steps and try again. I was able to reuse my pins but put a dollop of copper grease on before they went back.
Good luck, and be careful!
Old 22-02-09, 03:47 PM   #6
Alpinestarhero
My dad had this problem. after 2 hours, we had both pins out. without the need for drilling or cutting
My dad used alot of heat, and got some molegrips on the pins and just wiggled. Heat, wiggling. and some WD40. wiggle wiggle, eventuialy there was some movement. encouraged, he wiggled and heated and lubricated more and more
and eventualy, they came free.
Old 22-02-09, 04:05 PM   #7
mikebrooman
be careful of what? the heat buring me or something that shouldn't be heated near the pins?
So mole grips, heat, wd40 and patience?
Old 22-02-09, 05:23 PM   #8
Alpinestarhero
In a nut shell...yea
get some music on to help get you through. Once they come out, then clean them up (rub them down a bit with some emory paper or something? my dad put mine on a grinding wheel and lightly lightly cleaned them up that way), and put on copper grease before re-assembling. Then next time you need to service the brakes, everythign will come out
While you have the caliper off, why not pop the pistons out, clean them up, put on new dust seals and some red rubber grease. Fresh fluid too. mmm lovely back brake
Old 23-02-09, 08:03 PM   #9
svrich
Default Re: Rear brake pad retaining pins.
Yep, the heat gets me ever time. The caliper holds the heat very well!
Pad retaining pins dirtydog For Sale - SV's and SV related items 0 22-02-08 09:50 PM
Rear brake pins Viney Stuff Wanted 4 29-08-06 07:29 PM
Any one fancy some stainless brake pad retaining pins? jonacol SV Talk, Tuning & Tweaking 43 13-03-05 04:13 PM
rear brake pins syphonus SV Talk, Tuning & Tweaking 9 11-10-04 09:40 PM
Rear Brake Caliper Retaining bolts **WARNING** derbybiker SV Talk, Tuning & Tweaking 11 07-10-04 01:00 PM
