Old 01-02-05, 03:22 PM   #1
jonacol
Default Any one fancy some stainless brake pad retaining pins?
Just a thought after fiddling with the brakes the other day, I may make a pair of stainless pad retaining pins to prevent the corroded in pin problems. While I'm at it, would you lot be interested in a pair?(for beer money sort of price!)
JonC
Old 01-02-05, 03:23 PM   #2
jonboy
Yes, definitely.
Old 01-02-05, 03:36 PM   #3
Scoobs
Aye!
Will it stop the corrosion problems though???
What are the OEM ones made of?
Will they have a little hex on the end to get a socket on?
If I can think of any other questions I will let you know
Old 01-02-05, 03:57 PM   #4
BillyC
BillyC's Avatar
Yeah I think I'd be interested!
Old 01-02-05, 04:23 PM   #5
Viney
No ta. Got longer pins and drilled the blind hole out
Old 01-02-05, 04:27 PM   #6
BaggaZee
Sounds like a cunning plan!
I'd be up for it.
Old 01-02-05, 06:34 PM   #7
Stig
Having one seized pin and the pads requiring replacement shortly I would definitely be interested
Old 01-02-05, 06:50 PM   #8
jonacol
Well the pins won't corrode, I spose being pessimistic the caliper could still fur up in the blind hole but it wouldn't grip it like rust and a spot of coppaslip in there would fix it for def. The standard one's are just mild steel with the thinnest bit of plating? when new. My 4k bike had both pins well rusted and ****y looking. No hex req'd on end as they won't seize in :wink: it would be tres expensive/time consuming to machine a hex on, a flat would be sufficient at most IMHO ofcourse.
JonC
Old 02-02-05, 11:02 AM   #9
tee jey
A big yes please.
Old 02-02-05, 11:41 AM   #10
timwilky
timwilky's Avatar
I am up for these, drilling out my rear was real fun. Got to do fronts as well but rear has put me off doing it untill absolutely necassary.
Not Grumpy, opinionated.
Rear brake pad retaining pins. mikebrooman SV Talk, Tuning & Tweaking 8 23-02-09 08:03 PM
Pad retaining pins dirtydog For Sale - SV's and SV related items 0 22-02-08 09:50 PM
Brake pins..... tigersaw SV Talk, Tuning & Tweaking 4 07-02-06 07:37 PM
Brake pins Craig SV Talk, Tuning & Tweaking 13 31-03-05 07:16 AM
Rear Brake Caliper Retaining bolts **WARNING** derbybiker SV Talk, Tuning & Tweaking 11 07-10-04 01:00 PM
