Old 22-02-09, 06:06 PM   #1
WADERS
Default Faired to naked headlight, then blown bulbs.
Rebuilding 650s after crash swaping twin headlights for single unit to make naked/streetfighter bike. Fitted genuine single unit of 650 and blew light bulbs and main 30 amp fuse.
Q. Does the bike have a booster for the original twin headlight unit and would this cause the single headlight to blow?.
Q. If it has booster where is it located and can i remove it?
Many thanks.
Waders
Old 22-02-09, 09:30 PM   #2
maclovin
Default Re: HELP!! Headlight Conversion
bad earth on new unit ??????? can cause bulbs to blow
Old 23-02-09, 02:45 AM   #3
MattCollins
Fried regulator or bad earth as mentioned, but it could also be a bad connection on the +ve side. Time to pull out the multimeter.
Also, the globes are not being wrecked by fingerprints?
Old 21-03-09, 07:52 AM   #4
maxxdope
Default Re: Faired to naked headlight, then blown bulbs.
i have a buell single headlight and i am about to go naked on my 2000 SVs...
WHAT about the wiring harness ?
should i purchase one for a naked SV?
or from Buell?
Old 22-03-09, 08:13 PM   #5
WADERS
Previouse response correct many thanks, i found a bad earth. With regards the wiring loom, all i did was cut off the twined section of the twin head light loom, soldered the now spare black and white wire to the other black and white wire by stripping a little of the insulation cover and this worked a treat.
However, i used a genuine SVn head light so you may have to change the pligs the connect to the bulbs.
NEW HEADLIGHT BULBS Quiff Wichard Bikes - Talk & Issues 7 10-07-12 09:55 PM
Swapping headlights (bulbs) on faired pointy sauluk SV Talk, Tuning & Tweaking 2 23-01-09 07:04 PM
Curvy Faired Headlight Bulbs fenris SV Talk, Tuning & Tweaking 7 26-02-08 05:20 PM
naked , part faired, fully faired jans1971 Bikes - Talk & Issues 11 18-11-07 02:53 PM
Headlight bulbs stick Bikes - Talk & Issues 2 27-02-05 09:42 PM
