Old 05-03-09, 07:00 PM   #1
parker
Default Pointy rear lights pulsing.
Any ideas gents,
the first 3 bulbs on each side of my rear tail-lights flicker when idling, but are fine when I blip. The head-lights also seem to pulse until the throttle is applied, is it worth just changing the battery or should I start checking wiring first? what could cause both the front and rear to have a similar problemo?
Old 05-03-09, 07:13 PM   #2
Default Re: Lights pulsing
dont all bikes do that.
Old 05-03-09, 07:40 PM   #3
SVDragRacer
You could try uping the idle speed, might be a case that it's idling too low on the revs so not enough power is consistantly coming from the alternator which could cause the lights to flicker.
Old 05-03-09, 07:49 PM   #4
parker
yea i wouldn't have mentioned the headlights except the tail lights are clearly having a fit, I'll try upping the idle speed suggested by drageracer to see if that sorts the rear, may-well ease the front too...
Old 06-03-09, 12:16 PM   #5
vardypeeps
Sounds like an LED light on the back? If so I would check the connections on it as they may be loose. As for the front light they all do that so don't worry.
Old 06-03-09, 12:40 PM   #6
ophic
ophic's Avatar
K3 tail lights degrade and you made need to replace the unit.
Mine do it too.
The headlight... +1 for idle speed. Although you should expect it to be dimmer at tickover than whilst reving it - thats normal.
Silver SV650SK3, Fuel exhaust
Old 12-03-09, 01:49 PM   #7
parker
Finally got round to playing with the lights. Basically the idle speed was too low, increased it to the 1300 as suggested by the manual and the rear lights are honki-dori now. It was strange that only part of the tail light strips were flickering but its sorted now
Thanks for the advice folks
Old 12-03-09, 01:58 PM   #8
SoulKiss
SoulKiss's Avatar
K3 and K4 light units seem to have this - next step is for the LEDS to fail completely I believe.
Seems to not be an issue on later models tho.
Old 01-10-12, 05:15 PM   #9
tomtomskin
Hey Parker, I have exactly the same problem ( and age and colour bike as it goes). All my lights including the dash pulse at tickover. It takes over 2500rpm to get them to level out. I think it's down to a dying reg/rectifier. haven't attempted a fix yet but i will report back when i do.
Old 02-10-12, 02:42 PM   #10
650
650's Avatar
Seems standard on all SV's I've encountered. Don't forget that the wiring on these bikes is as cheese-tastic as all the nuts and bolts. A true economy bike if ever there was one!
650 is offline   Reply With Quote
Pointy rear lights with built in indicators Wez007 Bikes - Talk & Issues 13 26-11-11 08:08 PM
Clear rear lights, Pointy. Stimpy SV Talk, Tuning & Tweaking 2 23-04-10 07:13 PM
Pointy SV rear lights. LK-SV SV Talk, Tuning & Tweaking 7 17-11-09 05:09 PM
No side lights, brake lights, rear lights and dashboard lights Shona Bikes - Talk & Issues 25 13-11-09 11:07 PM
Pointy clear rear lights gettin2dizzy For Sale - SV's and SV related items 2 04-04-09 11:15 AM
