Old 07-03-09, 02:50 PM   #1
Pam
Default bike will only start if handle bars are turned to the left?
Ok guys n girls this is unusual? Only started this morn, my bike stalled and I started it as norm. Then parked for an hour or so. Now my bike will not start unless my handle bars are turned too the left. If I straighten them are try to start it all that happens is the head light dims. It runs perfect when started. I have checked the wires etc nothing seems to be loose or trapped. Any ideas please??? It’s the sv 650 K5 pointy.
Old 07-03-09, 02:55 PM   #2
Default Re: bike will only start if handle bars are turned to the left???
Clutch switch.
Old 07-03-09, 03:25 PM   #3
Stu
Trinity
Stu's Avatar
Clutch switch.
What he means is turning the handlebars to the left is the only way the clutch switch is working. try unplugging it & plugging it back in properley
Old 08-03-09, 12:29 AM   #4
phil24_7
Do all the ignition lights come on when it wont start or do they only come on when your turn the handlebars?
Old 08-03-09, 04:46 AM   #5
davepreston
Clutch switch.
+1
Old 08-03-09, 07:21 AM   #6
Bill.Cross
Clutch switch.
As I've said before - terse but true.
Tight under the clutch lever is a small electrical connection which can work loose. Jiggling the bats is jiggling this connection. Just push it home.
Old 08-03-09, 10:27 AM   #7
Pam
Hi yep, everything is normal on the bike ignition lights etc it just won't start unless my handle bars are even just slightly to the left. If they are not to the left then all that happens is the head light dims no noise/turn over etc. If I keep my finger on the button and turn the handle bars with my clutch still in it will start and run fine. I have jiggled the wires into the clutch switch etc, still nothing going to take off the switch today put it back on after a clean etc and see if that makes a difference if not will buy a new switch and go from there?
Old 08-03-09, 11:18 AM   #8
Nah don't bother with the clutch switch at all, if it comes to it, bypass the switch down in the loom to cut out possible points of failure.
Old 08-03-09, 04:55 PM   #9
Pam
It's not the clucth switch!!!
Even if the handle bars are just slightly to the left (very slightly) it starts fine, but doesn't start if it's straight or to the right but the elec/ lights are fine in any position....any ideas???
Old 08-03-09, 05:12 PM   #10
Try start it but instead of turning bars, wiggle the wiring loom.
Or try earth the black-yellow wire on starter relay. (clutch switch wire...)
Raising handle bars, advice? clanger SV Talk, Tuning & Tweaking 2 26-07-09 10:30 PM
Handle Bars Peaceful SV Talk, Tuning & Tweaking 20 11-12-08 09:40 PM
Handle bars advice Shellywoozle SV Talk, Tuning & Tweaking 9 16-08-07 11:15 PM
TL 1000 R Handle Bars... Fit SV650 K3 bobit69 SV Talk, Tuning & Tweaking 1 12-02-07 12:52 PM
WTB: 03-06 Suzuki SV 650 Stock Handle Bars Clipons nani Stuff Wanted 0 15-11-06 05:03 AM
