Old 10-03-09, 09:26 PM   #1
Yorkie Jones
Default How do you get rid of Scratches
Does any one know how to get rid of Scratches on Plastic, I have tried T Cut, but its not bringing it out
any one got any Ideas
Thanks
Old 10-03-09, 09:27 PM   #2
Default Re: How do you get rid of Scratches
autosol?
Old 10-03-09, 09:31 PM   #3
autosol?
NOOOOOOOOOOOOOOOOOOOO!!
It depends on how deep the scratches. I presume its on fairings?
I have something called Farecla G4, its a cutting compound used on new paints, and it polishes up to a nice shine.
I have only had to use it once or twice, when the usual t cut hasn't worked
Old 10-03-09, 09:40 PM   #4
fizzwheel
fizzwheel's Avatar
Depends how deep they are. If its through the paint then you wont get them out.
If not, try Auto Glymns Cutting Polish, worked a treat on my seat cowl after I scuffed it with my boot one day.
Old 10-03-09, 09:45 PM   #5
Frank
I had scratches on my plastics and ended up using a wax crayon of the same colour
Old 10-03-09, 10:15 PM   #6
gettin2dizzy
can you feel the scratch with your nail?
Old 10-03-09, 10:44 PM   #7
glade
glade's Avatar
As others have said, if it's through the plastic it'll be a respray.
If it's a surface scratch a cutting polish might help. Effectively you remove the paint/clearcoat down to the bottom of the scratch so that it disapears. Autoglym "Super Resin Polish" also "fills" the scratch with light polymer resins which helps.
The SV doesn't seem to have a clearcoat - based on the fact that if you polish it the paint ends up on the pad. Therefore you have to be careful not to remove too much paint when polishing, and not to polish too often because you could rub through the paint eventually.
After polishing, wax to protect the paint.
glade is offline   Reply With Quote
Old 10-03-09, 11:06 PM   #8
What are you using a brillo pad
Never had any of my SVs paint bleeding out onto the cloth. I always thought they had a clearcoat. In my yellow ones case the yellow is a pearl mica, and the paintshop sent a clearcoat out with the basecoat and yellow, when I had to to touch it up.
Old 10-03-09, 11:29 PM   #9
zsv650
ignore them and hope they go away work's for me.
Old 10-03-09, 11:54 PM   #10
Cover them over with more scratches.
Getting rid of small scratches Littlepeahead SV Talk, Tuning & Tweaking 9 31-08-08 03:50 PM
scratches george650 SV Talk, Tuning & Tweaking 13 22-02-07 05:01 PM
Scratches Anonymous SV Talk, Tuning & Tweaking 3 29-05-05 11:22 PM
Scratches on Windscreen Big Bad Al SV Talk, Tuning & Tweaking 14 21-09-04 05:15 PM
