Old 19-03-09, 12:08 PM   #1
pencil shavings
Default bleeding brakes, fluid level
Should the fluid be filled to the just below the upper level before the diaphram is put in? or put the diaphram in then fill it?
I filled it then put the diaphram in and it looks like it might over flow
cheers
Old 19-03-09, 12:34 PM   #2
pencil shavings
Default Re: bleeding brakes, fluid level
should the diaphram have any fluid in it?
sorry for the noob Qs
Old 19-03-09, 12:35 PM   #3
vardypeeps
Make sure you push the diaphram in on it's self so its all folded back together and if your worried put a rag around the top while you fasten down the lid.
It might be worth holding the bike upright to do it as there will be less chance of spilling fluid out of the res. Oh and yes top the fluid up to the upper line and then fit the diaphram and lid
Old 19-03-09, 12:38 PM   #4
pencil shavings
so abit of overflow is ok when inserting the diaphram?
Old 19-03-09, 12:41 PM   #5
vardypeeps
Well if it's topped up to the upper line it shouldn't really overflow as it allows for the diaphram?
Maybe take a little bit out but don't worry about it too much. As for fluid inside the diaphram empty it out before you fit it just to be sure.
Old 19-03-09, 12:41 PM   #6
sinbad
You don't want that to happen, it's horrid stuff, if it happens you've put a bit too much in. As long as the level is between the lines when it's back together you're set.
Old 19-03-09, 12:42 PM   #7
Stig
Fill to the upper level. Make sure the bars are in a position so as the fluid in the reservoir is level. Fully collapse the diaphragm and insert. The diaphragm should be just not touching the fluid. Overflow is not good. Brake and clutch fluid does horrible things to surfaces if not cleaned off straight away.
There should be no fluid in the diaphragm at all. The diaphragm will expand as the fluid drops as the brake pads wear out. The idea being no air is sucked into the braking system when the fluid gets low when going over bumps and such.
Old 19-03-09, 12:43 PM   #8
pencil shavings
thanks, but it will defo over flow if I put the diaphram in all the way. it is filled to about 3/4 way between lower and uppser. guess I should take some out?
Old 19-03-09, 12:43 PM   #9
vardypeeps
+1
That's what I meant to say
Old 19-03-09, 12:46 PM   #10
Stig
You have overfilled or the diaphragm is not fully collapsed. One of the two. Or the fluid is not level in the reservoir.
Bleeding Brakes - Again HopefullySoon SV Talk, Tuning & Tweaking 2 28-08-07 09:13 AM
Bleeding Brakes (Bleeding Kits) 21QUEST SV Talk, Tuning & Tweaking 8 20-06-06 05:31 PM
Bleeding Brakes sweepdoggydog SV Talk, Tuning & Tweaking 9 08-06-06 07:07 AM
Bleeding Brakes Moo SV Talk, Tuning & Tweaking 9 21-01-06 07:59 PM
Master brake cylinder fluid level after bleeding? kinesin SV Talk, Tuning & Tweaking 1 12-07-05 07:40 PM
