Old 20-03-09, 06:49 PM   #1
adam_castell
Default curvy parts for sale
all the stuff availible is listed below, nothing else is avalible apart from bolts and screws,
collection is welcome and is from dunstable, or from tring during normal work hours
contact me via PM for bulk discouts, plese title PM's with the part you are after
i will remove items from the list when i have recieved payment.
prefered payment is cheque, cash, or bank transfer
although i will take payment via PAYPAL, but please add 4% to cover the fees - adam_castell@hotmail.com
please write down which items you have brought when sending payment and you postal address if applicable.
i will not hold and wait for payment for longer than a week
items in red are reserved and awaiting payment
more pictures coming.
there are some duplicate listings, this is not a mistake, i have multiple numbers of some items
DESCRIPTION PRICE + P&P
airbox
£5.00 £4
axle rear, axle nut, and washers £5.00 £3.00
brake calliper rear £30.00 £5.00
brake calliper rear hanger
£5.00 £3.00
brake callipers front £40.00 £10.00
brake light assembly £15.00 £4.00
brake light assembly (cracked lense) £5.00 £4.00
brake master cylinder rear & reservoir £10.00 £3.00
brake torque arm £5.00 £3.00
carburettors
£40.00 £8.00
clutch lever (scuffed end) £5.00 £3
coolant reservoir £5.00 £3.50
engine 20,000 miles, runs well £250 £50
exhaust headers set standard £20.00 £15.00
fairing upper top bracket RH £5.00 £3
fairing upper bottom bracket RH £5.00 £3
fairing upper top bracket LH £5.00 £3
fairing tail piece (small scratch) £5.00 £3
fairing upper LH (scuffed and cracked)
£5.00 £5.00
fan £10.00 £5
fork springs standard, from bike with 12k miles £10.00 £5.00
frame, 2001 51 plate, V5, Tax & MOT till Sept, number plate included £120.00 £40.00
grab rail
£10.00 £4.00
heel plate RH (some marks) £5.00 £2.50
heel plate LH (some marks) £5.00 £2.50
horn
£5.00 £3
ignition coil F £5.00 £3
ignition coil R £5.00 £3
indicator rear LH (new in packaging, never fitted) £12.00 £3
indicator rear LH (slight scuff) £2.00 £3
indicator rear RH (slight scuff) £2.00 £3
indicator front RH minus black housing £1.00 £3
lock set (3 x locks and 1 x key) £40.00 £5
Mirror LH (scuffed)
£5.00 £3
number plate light £5.00 £3
mud guard
£20.00 £4
mud guard mounting brackets and bolts £5.00 £3
parking / side light
£5.00 £3
parking / side light £5.00 £3
pillion foot peg LH £5.00 £3
pillion foot peg RH £5.00 £3
pillion hanger LH £15.00 £3
pillion hanger LH (scuff on bottom) £5.00 £3
pillion / exhuast hanger RH £15.00 £3
radiator temp switch £5.00 £3
radiator hose RH £5.00 £3
screen standard £10.00 £4.50
seat catch mechanism £5.00 £3
side infill panel LH £5.00 £2.50
side infill panel RH
£5.00 £2.50
side stand
£5.00 £3.00
starter motor relay £10.00 £3.00
steering stem nut
£2.50 £2.50
suspension rear link £5.00 £4.00
swing arm
£30.00 £15.00
switchgear RH £20.00 £4.00
tank hinge bracket £5.00 £3
vacuum fuel pump £15.00 £3
vacuum fuel valve £10.00 £3
yoke bottom + stem £15.00 £5.00
Old 21-03-09, 01:54 PM   #2
Matthie
Default Re: curvy parts for sale
Can I ask why the rear brake caliper has gone up in price?
Old 21-03-09, 05:37 PM   #3
Thingus
PM'd
Old 23-03-09, 10:11 AM   #4
Thingus
Sourced somewhere else but a free bump anyway
Old 25-03-09, 11:09 AM   #5
Nicky S
Nicky S's Avatar
will svs footpegs and hangers fit on a sv ??
Curvy With Lots Of Bits ...
But Still More To Come
Nicky S is offline   Reply With Quote
Old 25-03-09, 11:15 AM   #6
Viney
Yes, they sit slightly further back, but they will fit.
Old 25-03-09, 11:27 AM   #7
Nicky S
Nicky S's Avatar
further back ????
Old 25-03-09, 12:11 PM   #8
Viney
Ok, i'll try to explain. The Triangle bits that fit to the frame on the naked, the sides are all equal in length, on the s, they are slightly longer on 2 sides, so the peg will sit slightly further back that they do on the naked. In all honesty if i hadnt said anything, you wouldnt have noticed. They will be fine.
Old 25-03-09, 11:53 PM   #9
Nicky S
Nicky S's Avatar
oh ok, are the rear ones the same or are they diffrent ??
Old 26-03-09, 10:33 AM   #10
arcdef
can i have side infill panel LH £5.00 £2.50 please.
Curvy parts for sale zxrneil For Sale - SV's and SV related items 2 23-04-09 06:41 PM
Parts for sale (Curvy 99) svgirl78 For Sale - SV's and SV related items 21 16-07-08 07:10 AM
curvy sv650 parts for sale riktherider For Sale - SV's and SV related items 4 21-03-07 10:53 PM
Curvy parts for sale Skip For Sale - SV's and SV related items 9 24-07-06 05:36 PM
curvy parts for sale BIKER-DENE For Sale - SV's and SV related items 3 07-04-06 10:24 AM
