Old 09-04-09, 05:38 PM   #1
BBadger
Default Noise and very hot brake disc.
Ok simple idea of whats going on.
Been comunting to london for 4 days now and its been fine.
Drive home and come back to it a few hours later today and something is not right.
there is now a "woosh woosh woosh" noise as i slow down and gets slower as i slow down.
Also the back disc is getting stupidly hot, so i didnt use it for a 15min run and get off the other end to find it hot ...yet again when the front discs were stone cold.
help im a machanical numpty.
Read pad is also on its way out ( could this be the issue ?? )
thanks brock.
Old 09-04-09, 05:42 PM   #2
hovis
Default Re: Eeeeekkk help!
how bad are the pads?
Old 09-04-09, 05:42 PM   #3
Mr Speirs
Mr Speirs's Avatar
That'll be the issue. Either worn pads, or piston siezed which would then cause worn pads.
Make sure you sort it soon otherwise you will start seriously scoring the disc.
Changing pads is super simple.
Old 09-04-09, 05:44 PM   #4
BBadger
Noooooooo. it had to be a bank holiday weekend aswell with sun, in england, life is cruel.
ill have a look at the break tomorrow me thinks and just take it easy on the trip home.
thankyou.
Old 09-04-09, 05:44 PM   #5
Sosha
Something is rubbing what shouldn't be. Take it off and acertain what & why....
sun? on a bank holiday?
Old 09-04-09, 05:47 PM   #6
BBadger
If its fixed and sunny. i shull not be saying hello over a cup of rykers tea!
To the garage!
Old 12-04-09, 03:32 PM   #7
BBadger
Default Re: Noise and very hot brake disc.
have replaced pads and feels 100times better.
But how hot should the rear disc get after only a little use, as i couldnt touch it without burning my hand earlier and that wasnt excessive use.
Old 12-04-09, 03:59 PM   #8
if you are still getting a whooosh whooosh sound, it could be a warped disc..
easy to check, raise the rear/front of the bike, spin wheel by hand, feel for any excessive tightening/resistance if there is any excessive resistance at a particular spot then a disc is warped.
Old 12-04-09, 04:48 PM   #9
BBadger
hmmm will check, and going for alignement aswell, but are these the only things that could be making it so hot?
Old 12-04-09, 04:51 PM   #10
Girth
As said could be,
Warped disc on rear,
Seized Piston,
Seized sliding pin on rear brake.
Brake Disc Problem leegriffiths128 SV Talk, Tuning & Tweaking 25 17-11-08 06:38 PM
Brake disc fubar'd ? leegriffiths128 SV Talk, Tuning & Tweaking 6 27-10-08 09:06 AM
Really hot rear brake disc Warthog SV Talk, Tuning & Tweaking 19 24-07-08 01:32 PM
Brake noise, warped disc? adw Bikes - Talk & Issues 6 21-08-07 07:33 AM
Brake Disc thickness andyb SV Talk, Tuning & Tweaking 7 14-11-06 10:49 AM
