On the way back from a ride out just now the speedo & rev counter went on the blink, kept cutting out. Everything else seemed ok so guessed it was something electrical.
Got it home, turned it off, went to turn it on again and nothing, not a thing would happen. No instrument lights, or anything. Turned the headlight off (which had been on when I tried to turn it on) and the ignition light and neutral light came on but still nothing else. So I went to check fuses, but before I got to look at them I saw that the battery was misshapen (like its sort of exploded inside) and it smelled a bit funny. So, obviously the battery has died a death in a big way. Ive now taken the battery out but not done anything else yet. So clearly I'll need a new battery, but ive not heard of this sort of thing happening before and wondering whether it's likely to be just the battery has gone bad for some reason (btw it was a maintenance free job), or whether its likely to be something else having caused the battery to do a self destruct job. Any ideas? |
Sounds like the reg/rec has died and it's overcharging. It's more common for them to fail and under-charge so the battery just goes flat all the time, but over-charging is another failure mode.
Don't fit a new battery without checking out the charging, if it is fubar then it'll take the new battery out as well. Electrex are a good supplier of quality replacement parts.
#3 | |
#4 | |
Thanks. Reckon it'll be a bidding war for that reg/rec you got your eye on then Dave!
Only kidding, thanks for the advice, I'll check out the reg/rec before I go wrecking a whole new battery then! |
#6 | |
The reg rec has failed closed and boiled it to death.
Like I've said before I don't see the point of replacing an SV RR with another SV one. The h*nda units keep a more stable voltage and by virtue of being over spec for the SV, appear to be far more reliable.
#8 | |
The Sick Man
the one on my SV has been fine for years, totaly stable at idle and throughout the rev range nearly the same voltage.
OTR: KTM 690 Duke R 2015 Full Akro SIDELINE: Kwak ZX636 A1P 2002, Red, R&G's, Yoshi, Double Bubble Screen GONE: Kwak ZX-7R P1, Full Akro, Undertray, Screen GONE: SV650S K2 Very Bruised & Without Fairing, Motovation Frame Sliders, R&G Ally Sprocket Toe Protector, HEL 2 Line Setup, GSXR K1 600 RWU Forks, Barnett Clutch & Springs, Penske 8981 Shock, Gilles Ti Rearsets, Steel Barends, Scottoiler, AFAM Chain & Sprockets, Twin FIAMM Horns, Skidmarx Bellypan, Full Micron Zeta Steel System, Cut down undertay. Forum Problems & Information / Site Suggestions |
#9 |
Sorry I meant the CBR ones commonly used. They are a little bigger than the stocker.
#10 |
The Sick Man
Personaly i think http://www.bbbikeshop.co.uk are the cheepest
The Day The Music Died | Interceptor | Idle Banter | 2 | 07-02-09 02:24 AM |
Pointy died on me. | Faisal | SV Talk, Tuning & Tweaking | 73 | 10-12-08 08:37 AM |
It died. Part 2 | yorkie_chris | SV Talk, Tuning & Tweaking | 8 | 15-10-07 04:26 PM |
It died on me... | yorkie_chris | SV Talk, Tuning & Tweaking | 7 | 12-10-07 11:10 AM |
HELP! My Bike Just Died On Me | g_conaty | SV Talk, Tuning & Tweaking | 3 | 11-11-05 01:09 AM |
