Old 03-05-09, 10:11 PM   #1
lmfy2k
Default ecu restrictor test?
hi just recently purchased and installed an ecu restrictor for my pointy k6, but is there any easy way to find out if the ecu restrictor actually works? cant feel any difference while riding on the bike?
Old 03-05-09, 10:25 PM   #2
ophic
ophic's Avatar
Default Re: ecu restrictor test?
is that to restrict it to 33bhp? I thought you had to change the whole ecu for that.
Silver SV650SK3, Fuel exhaust
Old 03-05-09, 11:15 PM   #3
Holdup
Did you replace ECU? it doesnt feel much diff because of the torque i find mine tends to lose all power at 8k rpm and top end is just below 100 on a flat, just get out and ride it (if you can) and see if you notice a difference
Old 04-05-09, 12:26 AM   #4
Jamiebridges123
If you can't tell if it's restricted or not, what's the worry? He said to the po leece
MOVING ON I hear it loses power above 8k. You would be able to tell coming from a full power ECU to a restricted one.
Old 04-05-09, 08:14 AM   #5
TazDaz
You should notice that the power band is shorter than a full power so you'll need to work through the gears more so. Just try and get 120 on the clock!
Old 04-05-09, 09:03 AM   #6
Drew Carey
Not Fizzwheel
Drew Carey's Avatar
Go to a private runway and open it up. If you can't get past 113-118 then it's restricted. If it keeps going then there's something not right.
"Feckinnnn Unluckkeeeeeeee"
Old 04-05-09, 09:06 AM   #7
Rocket
What is the part number on the item you purchased and installed?
Old 04-05-09, 10:49 PM   #8
lmfy2k
thanks for the info guys. will try out ure methods.
Old 05-05-09, 09:20 PM   #9
Mej
113-118
jesus, my bike wont get past 106 on the runway, what is the SVs real top end then?
Old 05-05-09, 09:32 PM   #10
Sally
Originally Posted by J2UK View Post
113-118
jesus, my bike wont get past 105, what is the SVs real top end then?
107 baby
Track though!
Restrictor jamesterror SV Talk, Tuning & Tweaking 4 20-04-09 04:26 PM
ECU Restrictor Naborralot Stuff Wanted 6 07-05-08 11:59 AM
Restrictor Naborralot Bikes - Talk & Issues 6 28-04-08 08:06 PM
Restrictor Ernie B SV Talk, Tuning & Tweaking 5 09-11-05 11:21 PM
Restrictor kit Saint Matt SV Talk, Tuning & Tweaking 9 10-06-05 07:44 AM
