Old 25-05-09, 04:26 PM   #1
davepreston
Question naked bars removal
how do you remove the bars from a naked
ive got the risers off but dont know how to seperate them to remove the bars, i asume the bolts are under the silver circular caps on top but how do you take them off without damaging anything cheers
Old 25-05-09, 05:20 PM   #2
Dave20046
Dave20046's Avatar
Default Re: naked bars removal
On mine there were caps across the risers (the bits that rise the bar from the yolk right?) two allen head bolts on each riser, if you remove these they should seperate so you can take the bars off.
Old 25-05-09, 05:25 PM   #3
davepreston
yea the risers split in 2 but there are 4 caps covering the allan bolts (last bit is assumption after your info) how do i remove the caps?
Old 25-05-09, 05:33 PM   #4
Dave20046
Dave20046's Avatar
Have you took the bolts all the way out dave the top parts of the risers should come off releasing the bars.
Attachment 4303
Old 25-05-09, 05:35 PM   #5
AndyBrad
screwdriver underneeth them
Old 25-05-09, 05:55 PM   #6
davepreston
now done cheers peeps on to next stage of naked rebuild (not me you cheeky gits the bike) switching throttle and levers across to the new rentals (cheers numbers)
Old 25-05-09, 05:57 PM   #7
Dave20046
Dave20046's Avatar
no problem, do not cut them too short though or you'll be ****ed. Better too long than too short you can trim them more if needs be. I only just saved mine from being too short, very almost had to bin them. File the lugs off the switchgears and wrap where they're going to sit on the bars in electrical tape. Mine are nice and wide make it easy to drop the bike into a corner very quickly.
Old 25-05-09, 06:02 PM   #8
davepreston
they are not getting cut at all the main thing im worried about is the throttle transfer if i f uc that up im in real drama land
Old 25-05-09, 06:12 PM   #9
Dave20046
Dave20046's Avatar
Aye probably a good plan, if you want to cut them to your own preference then you still can. should be okay just slide it all off one end and straight onto the new bars then do the other side. Probably best tackling the throttle first. You might need some boiling water and/or wd40 to remove the grip on the left.
Which bars to replace OEM on naked K5 tonny006 SV Talk, Tuning & Tweaking 30 08-10-08 04:41 PM
new straight bars on my sv naked jans1971 Bikes - Talk & Issues 13 27-09-08 03:21 AM
naked bars avvacuppa SV Talk, Tuning & Tweaking 11 05-08-08 08:48 AM
bungee bars removal Quiff Wichard Bikes - Talk & Issues 6 05-05-06 02:32 PM
WHAT BARS TO USE ON A NAKED SV.??? alexb SV Talk, Tuning & Tweaking 10 23-12-04 06:02 PM
