Old 10-06-09, 01:06 PM   #1
mrhighlyrated
Default clutch
Hi all,
I have another thread which is asking peoples thoughts on an engine rattle. We have worked out that its not the Cam Chain or Shims etc! I was speaking to my uncle in the Isle of Man and he mentioned it could be something to do with the clutch bearings? The rattle appears on acceleration and disappears when the clutch is pulled in. Also if the bike is just ticking there is no rattle.
Anyone have any thoughts??
Old 11-06-09, 08:12 AM   #2
mrhighlyrated
Default Re: clutch
BUMP! Anyone?
Old 11-06-09, 08:23 AM   #3
Holdup
Default Re: clutch
I would of thought it was just a general rattle, if you think its a problem then investigate it.
Old 11-06-09, 08:41 AM   #4
flymo
flymo's Avatar
Default Re: clutch
Originally Posted by mrhighlyrated View Post
Hi all,
This doesnt necesarily indicate a problem with the clutch. Pulling in the clutch obviously removes the load on the engine too which can point to a long list of possible engine problems, or gearbox, or drive chain etc.
Do you get a rattle at standstill when the engine is ticking over?
Old 11-06-09, 12:03 PM   #5
mrhighlyrated
Default Re: clutch
only occassionally do you hear a slight rattle, not often, as soon as you rev it, it lets off a rattle
clutch set up ?? leemole SV Talk, Tuning & Tweaking 4 10-02-08 12:51 PM
Clutch Problem? Cutting off when releasing clutch in first gear! puthsardarade SV Talk, Tuning & Tweaking 15 09-01-08 09:42 PM
hey new clutch advice Kyoto Clutch srxaus SV Talk, Tuning & Tweaking 3 14-08-07 04:25 PM
Do I need a new clutch? Ash999 SV Talk, Tuning & Tweaking 4 13-09-06 12:08 PM
Clear clutch covers to see the clutch spin while running. TLRMAN SV Talk, Tuning & Tweaking 13 01-11-04 02:18 PM
