Old 13-06-09, 01:45 PM   #1
Jabba
Angry Advice from (male) cyclists needed.....
As a recently born-again cyclist I need a bit of advice from the blokes on here.
To put it succinctly, what's the best way to prevent the...erm....well...err..*ahem* chafing in the "seating area"? Not that I'm suffering at the moment, you understand.
Do I need a specific type pants/undercracks/growlers/skidders* or would the issue be avoided with proper cycling shorts? Do I need specific undies even with cycling shorts?
TIA
*delete according to taste
Old 13-06-09, 01:53 PM   #2
Red Herring
Red Herring's Avatar
Default Re: Advice from (male) cyclists needed.....
A "friend" tells me you can buy padded underwear that is far more discreet and definitely less anorak than cycling shorts....
Old 13-06-09, 01:56 PM   #3
TazDaz
It's all about the seat in my experience and boxers which are "fitted" so to speak!
Movement = chaffing!
Old 13-06-09, 02:26 PM   #4
mattSV
mattSV's Avatar
Get some cycling shorts, and wear a pair of baggy 'cargo' shorts over the top if you feel a bit ghey wearing just the cycling shorts.
2000 - 2004 SV650S
2004 - 2009 SV1000S
Old 13-06-09, 02:46 PM   #5
V-twin
buy a specialised body geometry seat along with padded cycling shorts - £20-£30 quid. Don't buy the 'super thin' looking saddles as they will not prevent soreness. you need a saddle with padding
I have cycled long distances on a regular basis and find that THE SEAT is more important than the shorts. Angle the seat so it is parallel to the top frame. It's a case of going for short rides and then building up to longer distances.
I have managed 150miles of in the saddle without any real soreness, my knees just ached from the clip in pedals. not bad after 150miles in one day!!
Old 13-06-09, 03:02 PM   #6
speedplay
+1
I use cycling shorts and have no problems.
When racing I generally do about 300+ miles a week and dont suffer at all.
You will find that you will get used to riding again.
The other thing could be that your saddle is too wide for you.
Most people think that a wider saddle is comfier but only for women.
Old 13-06-09, 03:09 PM   #7
Ed
When I go running I often wear cycling shorts to avoid the same problem
Old 13-06-09, 03:12 PM   #8
CoolGirl
aww, poor Jabba got sore boy's bits (don't even think about asking)
That'll be all those meat-filled pastry products and cream cakes. I shall stop sending them fortwith if it helps.
Old 13-06-09, 03:14 PM   #9
speedplay
Being built like this wont help either...
Old 13-06-09, 04:11 PM   #10
Jabba
You haven't sent any for a while. Maybe that's the problem - not enough natural padding?
Hmmmm........ eat more pies. I like the sound of that
PC Advice needed FG1 Idle Banter 11 28-12-07 04:55 PM
Serious help/advice needed Paws SV Talk, Tuning & Tweaking 16 25-10-06 01:19 PM
Advice Please Fellow Cyclists fizzwheel Idle Banter 22 21-07-06 04:23 PM
Advice needed 650newb Exhausts 4 06-12-04 10:40 AM
Advice on value needed chog SV Talk, Tuning & Tweaking 8 15-11-04 10:00 PM
