Old 13-06-09, 03:31 PM   #1
krhall
Default Braided Lines - Are they worth it?
If so what are these like? http://cgi.ebay.co.uk/HONDA-CBR600RR...3%3A7|294%3A50
cheers,
Kev
Old 13-06-09, 04:03 PM   #2
rictus01
rictus01's Avatar
Default Re: Braided Lines - Are they worth it?
Much depends on where you're coming from really, on a fairly new bike the OEM lines will be fine, and given you have a sports bike probably more than fine, I'd wager your choice of pads would make more difference to brake "feel" than the lines themselves.
However, braided lines don't suffer the same as OEM rubber ones in the longer term as the rubber tends to "give a little" over time requiring more lever travel and can make them feel a little "spongy".
In order to address your question I'd need to know if
A.) you have a problem
B.) you just want general info
C.) you're just looking to add something to the bike (a bit of bling)
D.) you heard someone say you should have them
If A.) so what's the problem ?
If B.) see above
If C.) get some from busters of somewhere like that they'll make them to order with any fixings you want and coat them to colour match your bike to, and for less money.
If D.) your bikes not old enough to warrent replacing them, so don't worry about it.
Cheers Mark.
Old 13-06-09, 04:19 PM   #3
svdemon
Beware of earls lines, mine came and the sizes were way off. They dealt with it well but just don't expect to throw them straight on and you'll be reet.
Old 13-06-09, 04:25 PM   #4
Grinch
If replacing old, yes.
Old 13-06-09, 04:27 PM   #5
Alpinestarhero
I replaced my brake lines (9 years old at this point) with braided ones. It helped, but a month or two later i overhauled the calipers (strip, clean, grease, reassemble). And that gave the best improvment.
Old 13-06-09, 06:48 PM   #6
Listen to Rictus.
Old 13-06-09, 08:46 PM   #7
Swin
Swin's Avatar
Nice tip - I used Earls on my Bandit and they went straight on, I intend to replace the brake lines on mine next year as the oem's will be 4 years old by then - SV ones aren't as good by the sounds of it?
Riding a V-strom, well it has an Sv engine, don't it
Swin is offline   Reply With Quote
Old 13-06-09, 08:54 PM   #8
muffles
From my experience it will make the lever a little firmer and that's about it. That's based on trying both options on my cbr and my 750 (in the case of the 750, I was comparing against my mate's year-older 600 with braided lines).
Old 13-06-09, 09:35 PM   #9
That's all they're supposed to do.
Old 14-06-09, 06:35 AM   #10
muffles
I know I worded it badly but I meant that in response to comments that it would not be noticable when replacing new rubber lines. I could feel a difference on the gsxr...
Braided brake lines worth it? TheStudent SV Talk, Tuning & Tweaking 2 01-02-09 05:18 PM
braided lines xbox650 SV Talk, Tuning & Tweaking 23 02-12-08 04:45 PM
HEL Braided lines Couerdelion SV Talk, Tuning & Tweaking 7 30-05-05 07:13 AM
HEL Braided lines mysteryjimbo SV Talk, Tuning & Tweaking 8 10-02-05 10:20 PM
Braided Lines 454697819 SV Talk, Tuning & Tweaking 14 08-01-05 03:37 PM
