Old 18-06-09, 12:21 PM   #1
demonicus
Default footpegs
hi all, is it possible to fit slightly larger footpegs to a 99 curvy as my feet are size fourteen and i have had problems keeping my feet on, modified the brake lever with a big bolt straight through with rubber sheathing to give me a fighting chance.
and no i dont want to put running boards on!
Old 18-06-09, 11:27 PM   #2
Default Re: footpegs
me dont know..
but one thing for sure-
make sure you have rubber on the top if you do change em..
I put none rubber on for a bit when me had a curvy and it shook me feet to bits with the vibration..
Old 18-06-09, 11:28 PM   #3
oh and are you new?? 15 posts only--
see EDIT--- rideouts and meetings section... and shelleywoozles BBQ she lives in stafford..
Old 19-06-09, 09:38 AM   #4
flymo
flymo's Avatar
Size fourteen! thats practically a snow mobile
Old 19-06-09, 10:55 AM   #5
davepreston
im surprised by this im a 13 and have no issues but that the hay a set of rear sets will sort you out with a little *******iseation, spacers will also work but be aware you will lose lean angle if you are a knee slider
Old 22-06-09, 03:49 PM   #6
demonicus
thanks all, i have since changed boots to hi tec magnum hiking boots. believe it or not that has stopped the problem!i have had a look at a couple of rearsets though as a more permanent solution. knee slider, dave! i am a born again biker after several years off, so confidence is building way too slowly and chicken strips are still as wide as the m6.
Footpegs zigrat SV Talk, Tuning & Tweaking 2 06-04-09 09:21 PM
modifying footpegs erik SV Talk, Tuning & Tweaking 14 08-02-09 06:44 PM
rear footpegs FG1 For Sale - SV's and SV related items 0 09-12-08 11:28 PM
Passenger footpegs kolby Stuff Wanted 0 06-07-08 10:28 PM
Footpegs Viney Stuff Wanted 4 07-05-06 08:38 AM
