Old 23-06-09, 08:18 PM   #1
ianc
Default Turn key...nothing happens
Hi all (I did try searching first...no joy!)
I've got a 2004 pointy which is completely original apart from LED indicators.
I noticed a couple of days ago my alarm kept going off, nothing seemed unusual, re-armed it with no problem.
Got to get on it this evening turn the key...nothing! No noise, lights...NOTHING! Checked the battery which is fine.
Any ideas people, could this be related to the alarm?
Any input appreciated!
Cheers, Ian
Old 23-06-09, 08:32 PM   #2
simesb
Default Re: Turn key...nothing happens
Could be the alarm, or could be the connectors behind the headstock. Check the green one for signs of arcing - it may be the culprit.
Old 23-06-09, 08:44 PM   #3
fizzwheel
fizzwheel's Avatar
Check the main fuse, not to sure where it is in a pointy though...
Old 23-06-09, 09:57 PM   #4
seedy100
Kill Switch?
Old 23-06-09, 10:01 PM   #5
thefallenangel
watch out. If your battery is run completely dead as a dodo as anyone on the washed out rideout to Barnstaple that gid's bike battery was killed off from his alarm so bad no lights or anything. Try jump starting off something else first if the alarm has been playing up.
Old 23-06-09, 10:06 PM   #6
simesb
Originally Posted by seedy100 View Post
Kill Switch?
Would still get clocks, but no starting.
Old 23-06-09, 10:30 PM   #7
sv650nutter149
it will be the fuse for def located by battery
Old 23-06-09, 11:00 PM   #8
Dan
IIRC haven't there been reported issues with the ignition barrel connections on SVs?
Old 25-06-09, 10:23 AM   #9
warrenhewitt10
mine does that occasionally..... but my problem is resolved by moving the handlebars side to side, then it will come to life as normal. I posted a thing on this but no1 seemed to have any idea why it happens
Old 25-06-09, 10:27 AM   #10
simesb
In your case I really would recommend checking the green plug behind the headstock - it's exactly the same symptoms as mine (K3). Next time it happens, wiggle the wire that goes from the ignition barrel into the frame on the right - you may find it remakes the connection.
Can I turn up? 454697819 2009 Annual Rideout 16 17-06-09 09:47 PM
02 SV needs new turn signals s3rv3nt SV Talk, Tuning & Tweaking 2 07-10-08 12:31 AM
Key wouldn't turn hedgehog SV Talk, Tuning & Tweaking 12 01-09-08 03:28 PM
Joke (my turn to try!) Filipe M. Idle Banter 7 25-08-06 05:12 PM
