Old 24-06-09, 11:09 PM   #1
newts924
Default Brakes upgrade
As title say's
I am thinking of upgrading my brakes but don't know which pads to go for and what type of lines should i get.
Is it worth upgrading the rear brake as well or would just doing the front brake be ok.
Finally where is the best place to get the parts that i need. Its a K6 faired.
Thanks in advance
Old 24-06-09, 11:18 PM   #2
Default Re: Brakes upgrade
EBC HH are good with the standard calipers, strong but still road-oriented. There's more powerful but I think you lose too much control/subtlety... With a K6 your standard hoses should still be OK, unless it's got high miles on, rubber hoses work fine but they wear out. (people replace worn out rubber hoses with braided hoses, or replace good hoses and old fluid with new hoses and new fluid, and they're amazed by the difference )
But if you want to do it at the same time, it will never hurt and they're not expensive. I use HEL but they always seem to be too long, even my custom made single line turned up half a foot longer than it was supposed to. Scooby Drew's set for his Ninja were enormous, so we ended up fitting an old SV set I had lying around which were the wrong size for an SV but perfect for a Ninja, funny old game. They're a great company and they always put things right but they can be a pain sometimes. I still like them and I'd use them again.
Old 24-06-09, 11:22 PM   #3
Holdup
Do you use both front and rear brakes?
How many miles has your bike done may be worth doing an overhaul
Lines goodridge or hel
Front race set up 2 lines from master cylinder to calipers 1 each get steel banjos instead of zinc you may have to pay extra
Rear may be worth replacing as yours will prob be coming up to 3 years old maybe older now
EBC sintered pads as well
Mine consisted of EBC sintered front and normal EBC rear from a motorfactors
Good ridge hoses front race set up, rear single (zinc fittings i couldnt afford steel) from fleabay
seals from dealer as i needed them that day
HTH
Old 24-06-09, 11:38 PM   #4
Oh, I forgot about the rear. One of the rear calipers I bought had EBC HH in it, and they were horrible, just power and no modulation. Standard hoses can take some bite out of the rear, which a lot of people would say is good, but I don't like it- it reduces bite but it also takes away control. What I've got myself is a steel hose, but the EBC Organics pads- which are basically their least powerful pad. There's still enough power there if I go looking for it but there's a far more usable spread of braking. Or at least, there is for me, but braking is a pretty personal thing so ymmv. Carbon Lorraine A3 would do the same job I expect, I used to use those as front pads and loved them, but I don't think they'd work well with SV calipers. Magic with GSXR calipers and big discs.
(I don't like bite, journalists and racers love a big initial bite but if you're commuting in winter you want to be able to apply a tiny amount of brake without it biting you. This is the main reason I love my single caliper/huge disc setup, it has more power than standard but it's only there when you ask for it- 1% lever gives 1% power, and so on. I can't see how anything else is a good idea, but I seem to be in the minority, most people seem to like a big initial bite. If I want a load of brake, I use a load of lever, I don't want to use 10% of the lever and get 30% of the power when there's only 20% of the grip available.)
Old 25-06-09, 01:48 PM   #5
Paul the 6th
Paul the 6th's Avatar
eyup shane, still got the hel braided lines from my k5 650 if you're interested
another +1 for ebc sinterred hh pads, really nice sharp bite to them. The brakes on my sv1000 felt Rrrrrrubbish when I took it for a test ride (well, compared to the 650 anyway). Think I'll be getting some braided lines and fresh fluid to complete the set up (I've only fitted the ebc pads since I've got it - has improved a bit but think the fresh fluid will do it)
Old 25-06-09, 04:10 PM   #6
thefallenangel
how about going for the 4 pot calipers if you wnt a real brakes upgrade?
I have the adaptor plates beside me but can't be bothered doing them. That apart from a full GSXR front end swap will be the best brake upgrade around.
Old 25-06-09, 09:45 PM   #7
newts924
Hi mate,
Do these come with all the fittings as well, if not do you know where i would be able to get them from?
Also where is the best place to get the pads from as i checked on ebay and cant find any for my bike .
Old 25-06-09, 09:48 PM   #8
simesb
EBC HH for the pointy on ebay - here
back ones also available
Old 25-06-09, 09:52 PM   #9
Paul the 6th
A far as I'm aware the lines make use of all the existing bolts, banjos etc.. I'll check with tc though to avoid misleading you ebc direct (type ebc direct in google) sell pads direct. Not ridiculously expensive but there's sometimes a discount on postage
Old 25-06-09, 10:00 PM   #10
newts924
Thankyou
The next upgrade? pmapp SV Talk, Tuning & Tweaking 0 28-08-07 04:28 PM
Suspension Upgrade svdemon SV Talk, Tuning & Tweaking 3 18-08-07 02:15 PM
Brake upgrade danf1234 SV Talk, Tuning & Tweaking 22 02-07-07 02:30 PM
Fork Upgrade TSM SV Talk, Tuning & Tweaking 7 13-07-05 11:42 PM
SV upgrade, advice please sprocket SV Talk, Tuning & Tweaking 4 18-03-05 09:56 AM
