Old 07-07-09, 10:40 PM   #1
hallasv
Default Exhaust popping noise?
I have a SV650-S 99-02 running a stock exhaust with a drilled baffle (2x4mm holes)
Noticing lately when idle especially, there is alot of splutter, popping or spitting noise coming from the exhaust. Too the point where near buying a new exhaust that noticable.
Is this a exhaust problem or something else?
Old 08-07-09, 08:00 AM   #2
Alpinestarhero
Default Re: Exhaust popping noise?
sounds like the fuel/air mixture is too rich (too much fuel). Is the choke ok?
Old 08-07-09, 09:56 AM   #3
hallasv
had the choke out not so long ago, and seems to be ok. Could it be a loss of back pressure from the drilled baffle?
With getting a new aftermarket exhaust how would I adjust this to suit?
Old 08-07-09, 10:04 AM   #4
warrenhewitt10
the carbs probably need balanced. i had a mate whos bike was doing something similar and thats wot the problem was!
Old 08-07-09, 10:09 AM   #5
hallasv
had a feeling it might be that.... curses.
Will get my new exhaust first then get round to that to avoid further costs!
Also noticed other day, took the bike for a good run, and found a empty road and gave it some rag, when got over 100 alot of black smoke came out of the back. Could this be a sympton of running lean/rich or could it be just the fact I never really gun the bike much?
Old 08-07-09, 10:13 AM   #6
Binky
Emily Howard rides an SV
Binky's Avatar
I may be completely wrong here, but is black smoke not when you overfill with engine oil??? Or is it white/blue smoke???
Wowee Zowee
Old 08-07-09, 10:14 AM   #7
hallasv
oil when burnt makes a bule/white smoke. This was black as ace of spades, so presuming either settled carbon in exhaust or bike running rich?
Old 08-07-09, 10:14 AM   #8
warrenhewitt10
thers wot the service manual says about that sorta thing..
Old 08-07-09, 10:19 AM   #9
hallasv
hmmm im thinkin worn piston rings there as does tend to use alot of oil lately...
But the smoke never comes out really except for that once :S
Old 08-07-09, 10:26 AM   #10
warrenhewitt10
the bike wasnt de-restricted recently was it?
Exhaust Popping And Banging Stewbie SV Talk, Tuning & Tweaking 10 01-02-09 02:31 PM
After market Exhaust popping...bad? Kinvig SV Talk, Tuning & Tweaking 8 21-08-07 07:10 AM
OK What was that? (popping noise on stall) Baph SV Talk, Tuning & Tweaking 1 18-12-06 10:55 AM
popping exhaust at idle? toyotafj40s SV Talk, Tuning & Tweaking 5 21-08-06 01:31 PM
Popping exhaust (and shiny wheels) Carl SV Talk, Tuning & Tweaking 3 06-04-05 01:17 PM
