Old 10-07-09, 03:36 PM   #1
TC3
Default Just added a power socket
After my Garmin which i mount to rev counter, ran out of juice just when i needed it in France i thought i would add a socket to charge it and give it constant power. Will also be handy for charging mobile in my tank bag as well as powering my tyre inflator.
I have only zip tied it but is solid and can always move to another location if need be. Looks better than in the pics and works well. Not sure about location though. What you guys think? Does it look silly where i have attached it?
Old 10-07-09, 03:37 PM   #2
thefallenangel
Default Re: Just added a power socket
i got the faired R+G's on my semi and it fits perfectly into housing.
Old 10-07-09, 04:01 PM   #3
You what?
Old 10-07-09, 04:05 PM   #4
thefallenangel
You what?
Semi-faired. Blunder-road used the wrong ones on my SV. So i have the housing ready for the full fairing but not the full fairing
Old 10-07-09, 04:13 PM   #5
TC3
What are you talking about and what has it to do with my post i am wondering?
Old 10-07-09, 04:14 PM   #6
thefallenangel
mine is mounted in the middle of there. And i just realised i talk jibberish.
Old 10-07-09, 04:30 PM   #7
,,,,,,,,After my Garmin which i mount to rev counter,,,,,,,,,
doh.. what a top tip... now why the hell didn't i think of that... stick the sucker to the rev counter.. genius..
and no it look great where it is...
Old 10-07-09, 04:32 PM   #8
TC3
ok now i understand
Old 10-07-09, 04:58 PM   #9
TC3
Sticked to rev counter for a good 2 hours and did not come loose at high spped at all. The genuine Garmin car charger has an L shaped mini usb socket and across this i put a few strips of black insulating tape to hold the wire againt the body. Should the bracket ever come loose then the garmin unit wont fall but just hang a lil so you wont lose the beloved satnav.
Great if it looks ok then i will leave as is for now
Old 10-07-09, 05:18 PM   #10
nobby
I have mine just behind the headlight on the insde of the off side bracket facing down (curvy). Nothing to be seen when its not in use, when I shove the sat nav car charger in I wrap the lead around the indicator once then off to the sat nav...works well
Fitting cigar socket - power from where? harvy SV Talk, Tuning & Tweaking 8 22-06-09 06:55 AM
Wiring a power socket? DEJA_Vu SV Talk, Tuning & Tweaking 7 02-02-09 12:18 AM
power socket fitting kit, any good? Brettus Bikes - Talk & Issues 11 22-05-08 07:03 PM
Power Commander power graph print outs. JimPSV SV Talk, Tuning & Tweaking 19 27-11-06 09:39 AM
12v power socket? Baldyman SV Talk, Tuning & Tweaking 14 20-05-05 04:55 PM
