Old 15-07-09, 04:39 AM   #1
mister c
mister c's Avatar
Default Pointy Regulator on a curvy
I have been on the search, but got fed up after the 2nd page.... Sorry.
I have a regulator/rectifier off a pointy. It has 4 wires whereas the curvy one only has 2. Can I fit the newer Reg to the older bike?
Old 15-07-09, 07:35 AM   #2
Default Re: Pointy Regulator on a curvy
Hopefully you're referring to the output block and the new reg/rec has got seven wires all together as opposed to the five of your original; three in one block and four in the other, the block with four connections is the output, and simply there are two pairs of wires; two lives and two neutrals.
Old 15-07-09, 07:44 AM   #3
mister c
mister c's Avatar
I did think that with them being the same colours, many thanks, always best to double check. Cheers Sid
Rectifier regulator for a curvy KyleX Stuff Wanted 6 26-05-09 10:28 PM
Curvy SV Regulator Rectifier Dave20046 Stuff Wanted 0 12-04-09 04:25 PM
Curvy Regulator/Rectifier JamesMio Stuff Wanted 7 11-06-08 04:13 PM
regulator needed, curvy 2001 NadineDieBiene Stuff Wanted 10 03-11-07 05:31 PM
Regulator/Rectifier for a curvy. Biker Biggles Stuff Wanted 0 21-05-07 01:38 PM
