Old 19-07-09, 07:41 PM   #1
flymo
flymo's Avatar
Default My Honda CR250 project :-)
I'm finally getting to take a look at my CR250 project after a couple of years of having it sat in the back of the garage.
Are there any CR experts out there that I might be able to bounce questions off along the way?
Is there an equivalent to alpha-sports online parts diagram for these bikes anywhere? (Found one ) Good sources of spares etc?
I 'think' its a 1989 CR250.
Old 20-07-09, 11:09 AM   #2
Alpinestarhero
Default Re: My Honda CR250 project :-)
its going to kill you.
BTW, good luck! pictures please
Old 20-07-09, 11:11 AM   #3
hovis
im not an expert, but had a few and may be able to help with some Q's?
Old 20-07-09, 11:13 AM   #4
flymo
flymo's Avatar
the more I look the more problems I find
This thing is a deathtrap as it stands, I was stripping the rear end from it last night. The wheel bearings are totally knackered, no real drama there. Getting the rear axle out took about 30 mins, it was stuck fast with all the old grease gone hard. Eventually released it, seems to be fine with no wear along its length although the axle nut is knackered and will need replacing.
So, got the rear wheel off and removed the brakes. Nothing too bad, the brake piston even moved when I pressed the lever! Only problem here is a stuck rusty bleed valve. Will have to give that some time one evening and remove it. Obviously needs replacement piston seals and fluid etc. Havent decided if I'll be replacing the rubber hoses yet.
The main worry was the suspension linkages under the swing arm, it has a similar arrangement to the SV but the dogbones are replaced by a U shaped bracket that effectively does the same thing. The big problem here though is that one of the linkage arms (think dogbones) has been snapped clean in two and bodged with a strip of alluminium plate bolted to its side! Piccies on the way later today.
Old 20-07-09, 11:20 AM   #5
plowsie
Indeed, that is a bodge
Be good to watch this go on mate. Get her fixed up and take her to Anglesey Win the Minitwins race on that
Old 20-07-09, 11:37 AM   #6
flymo
flymo's Avatar
Okay, a couple of pics to get started.
This is the bike, it is all there just most of the rear end parts are on a shelf
Hows this for a failed suspension fix? Wouldnt want to land a big jump on this thing.
Old 20-07-09, 11:39 AM   #7
flymo
flymo's Avatar
Its going to take a bit longer than a few weeks I reckon this one.
Old 20-07-09, 11:40 AM   #8
plowsie
Pah, amateur
If it's gonna take a while, you have to give it a name such as mine - Snail.
I suggest, project 'tortoise'
Old 11-06-10, 08:51 AM   #9
flymo
flymo's Avatar
Originally Posted by daz1234 View Post
,bnnc kkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkk
yeah, your keyboard works.
If you wanted a Honda buy a Honda... Not a Honda SV sv_rider1990 Bikes - Talk & Issues 26 16-06-08 02:33 PM
CR250 front wheel spindle flymo Bikes - Talk & Issues 1 01-04-08 10:16 PM
Project TLS PAPPACLART Photos 65 15-08-07 09:14 PM
FOR SALE : 1977 HONDA 400FOUR PROJECT - NOW ON EBAY!! Last Action Pimp Idle Banter 30 05-02-06 08:47 PM
BAR Honda versus HM Plant Honda curium Bikes - Talk & Issues 2 10-11-05 10:51 AM
