Old 02-08-09, 03:05 PM   #1
silversurfer
Default Fitting Fuel exhaust - help please.
ok, just got my new fuel, fitting now, about to start the cutting :s
BUT flicking through the instructions it says "put small amount of sealant in inlet pipe"... doesn't say what type of sealant etc
so... will silicone do? is it heat resistant?
or if not, what should i use???
is it necessary?!
cheers!!
Old 02-08-09, 03:06 PM   #2
silversurfer
Default Re: Fitting Fuel exhaust - help please!!
ps it's a pointy SV
Old 02-08-09, 03:08 PM   #3
FG1
You will probably be ok to use............................nothing.
Lots of people have fitted new cans and not used a sealant. Me incuded.
Old 02-08-09, 03:33 PM   #4
wattyfred89
wattyfred89's Avatar
Hello....I have a feul end can and i read that after i fitted it...Ha
... so i went out and got some and fitted it twice.........just dug out what i used.....its called HOLTS FIREGUM its just a heat proof exhaust assembly sealant.
wattyfred89 is offline   Reply With Quote
Old 03-08-09, 02:59 AM   #5
L3nny
L3nny's Avatar
I've had a Fuel end can on my bike for about 5 months now and never bothered with sealent. It'll be reet
2015 GS 1200 Adventure
Old 03-08-09, 05:32 PM   #6
thefallenangel
Default Re: Fitting Fuel exhaust - help please.
if that bothered, gun gum is the exhaust sealant. You'll be in the minority who use it though.
Old 03-08-09, 05:41 PM   #7
thedonal
I was told that the best way to put sealant on is to heat the end of the open pipe (the bit you've cut to fit the new slip-on link pipe over), then wet it. Then apply the sealant.
This way, it creates a seal on the end of the pipe and expands before you fit the link pipe over.
I found when I used firegum without doing this that it just all expanded and came out of the gaps in the end of the link pipe assembly, so didn't really make much of a seal...
Old 03-08-09, 05:51 PM   #8
Spanner Man
Good evening all.
Believe it or not bathroom RTV type sealant is pretty good on exhaust can joints, & it's cheap too! Just a thin smear is all you need.
Cheers.
Spanner Man
Old 03-08-09, 08:58 PM   #9
GavinD
all 4 of my fuel exhausts have nothing sealing them at all - machining is so good its a friction fit
Old 04-08-09, 10:40 AM   #10
stuballs
you have 4 fuel exhausts on you bike?
just got Fuel exhaust for Birthday, Weather=Cr*p!, fitting advice pls mattb200 SV Talk, Tuning & Tweaking 5 17-05-08 08:53 PM
gasoline in my exhaust... fuel in my exhaust mtb83201 SV Talk, Tuning & Tweaking 5 29-04-08 10:58 PM
Fitting Fuel Exhaust plowsie SV Talk, Tuning & Tweaking 9 26-05-07 01:24 PM
Fitting a Fuel Zorst DanDare Exhausts 11 22-05-07 09:23 AM
Fitting Quick release Fuel Cap heathsv65063 SV Talk, Tuning & Tweaking 1 25-07-06 07:14 PM
