Old 10-08-09, 08:24 AM   #1
XmisterIS
Default I have a cunning plan ... *cackle*
I ride a naked pointy and I would like more headlight power!
I had considered a full re-jig of the lighting system - i.e. fit a pair of twin headlamps in place of the single ...
*BUT*
Then I had a cunning plan, inspired by a mod to a naked Bandit 600 I saw on another forum. The guy had attached two clamps to the tops of the forks (just under the headlamp), and had fitted a pair of small headlamps onto the clamps, each one taking a standard H4 bulb. He'd then fitted a switch to the handlebars to switch on the extra headlights as required.
Result: 3x the headlamp power at the flick of a switch, without having to do anything at all to the existing headlamp!
Clever Banditman ...
I would love to do this to my SV. Any suggestions about how I should go about it, in terms of fitting the electrical components?
I am not too clued up on motorbike electricals, although I do understand the principle of how electricity works! (that's a good start, n'est pas?!).
Old 10-08-09, 08:34 AM   #2
Caddy2000
Default Re: I have a cunning plan ... *cackle*
You could just fit a HID kit........
Old 10-08-09, 08:37 AM   #3
XmisterIS
I found a website with some good looking options: http://www.motorcycle-parts-accessor...eadlights.html
I thought HIDs weren't road legal? Can you stick a normal H4 in a HID lamp? And if so, could I just stick the HID kit on in addition to the OEM headlamp?
Sorry if I am being thick, just I don't know a lot about these lights!
In particular, I don't know about the legality of HID kits ... I've heard some people say they're legal, some say they're not ... I'm confused!
Old 10-08-09, 08:53 AM   #4
custard
some hids arent legal...
let me know how you go with this, have been thinking about doing something like this for a while.
Old 10-08-09, 08:54 AM   #5
XmisterIS
Do you know which ones aren't legal and how can I tell?
I will keep you posted
Old 10-08-09, 09:05 AM   #6
Caddy2000
I think the web site you'll need to look at is something like
www.his-4-u.co.uk
could be wrong.
As far as I know you can get a HID H4 bulb, so not much messing around.
Plenty of people have done this, try a search of the forum.
Old 10-08-09, 09:37 AM   #7
Red Herring
Red Herring's Avatar
I've got a set up that goes onto my K5 consisting of two Hella lights i bought from a car accessory shop. I've taken a seperate fused live from the battery to a relay I've put behind the existing headlights, then then fed the Hellas from the relay. I then spliced a wire into the "high beam" feed to the headlights and used this to trip the relay. That way the Hellas only come on with high beam.
Old 10-08-09, 09:52 AM   #8
Caddy2000
I saw an article in a Landrover mag about adding additional lights that said that the lights would need an additional switch even if they were wired into the high beam circuit - Apparently a legal thing......
Old 10-08-09, 02:33 PM   #9
Red Herring
It depends on the wattage. On the road the most powerful allowed are 55w (I think) so if they are more than that (and some of the searchlights I've seen on Landrovers look as if they should be!) you will need to disable them for use on the road, and technically fit covers over them as well. (Like rally cars do).
Old 10-08-09, 04:45 PM   #10
XmisterIS
Can you have as many 55W lights as you like, provided that each light is no more than 55W?
I have a plan so cunning, you could put a tail on it and call it a fox! Jayneflakes Idle Banter 56 05-01-09 01:37 AM
I have a plan so cunning... Neeja Idle Banter 1 25-08-08 08:06 PM
i have a cunning plan hovis Bikes - Talk & Issues 31 20-10-06 09:58 PM
A cunning plan falc Guildford Massive 26 06-08-06 12:41 AM
Cunning stunts 'n SV's... ronnus SV Talk, Tuning & Tweaking 29 26-07-04 04:25 PM
