Old 15-08-09, 03:12 PM   #1
Jamesey
Default Handlebar mounts
Having no luck in sourcing second hand mounts/clamps for a 2000 reg naked yoke and handlebars.
A local engineering shop said they could make up clamps for around £60.
Bit worried they will be strong enough, didnt ask exactly what they would be made from!
Anyone else went down this route?
£60 an ok price?
Old 15-08-09, 03:25 PM   #2
Default Re: Handlebar mounts
which bits are you wanting exactly? The risers which bolt to the yoke and hold the handlebars in place?
If so I've bought them secondhand for £30 ish. Bandit ones are about the same, in fact nearly any naked bike.
Old 15-08-09, 03:33 PM   #3
Jamesey
Thats what Im needing chris, cant get second hand ones anywhere.
Priced new ones from Suzuki, nearly fainted at the price!
Does any bandit ones fit?
Old 15-08-09, 04:41 PM   #4
CheGuevara
I bought Renthal ones new off ebay for ~£25 or so. There were lots on there, but I expect you'd have to be careful-ish as the bolt sizes seem to vary.
- K9 SV650S: Hel brake lines, carbon end can
- SZR660: The project...
- K5 SV650S: K7 GSXR750 front end, ZX6RR shock, GB Moto rearsets, Hel brake lines, Renthal risers, Tuono bars, V-Rod headlamp, "JMV" belly pan ~SOLD~ (wonder where it is now)
CheGuevara is offline   Reply With Quote
Old 15-08-09, 04:43 PM   #5
IIRC (will check in a minute) stock SV650 bolt to hold the riser to the yoke is an M10 and the bolts to clamp the risers together are M6.
There is LOADS of meat in the top yoke if you had to drill it out to M12 or something though.
Old 15-08-09, 06:10 PM   #6
Jamesey
Have seen a few renthal ones on ebay for 22mm bars, but dont mention the fixing bolt size or have double bolts to fit to the yoke.
And are they called clamps, mounts or risers?
The parts link at the top of the page calls them HOLDER HANDLE LOWER and HOLDER HANDLE UPPER!
Old 15-08-09, 06:50 PM   #7
Razor
Risers, usually.
These look close and I think that's the kinda price to pay too.
Old 15-08-09, 07:04 PM   #8
Standard bars are 22mm or 7/8".
Those on the eBay link are REALLY high, stock is only like 20mm of rise and even then you benefit from lower bars.
Old 15-08-09, 07:04 PM   #9
Jamesey
They look ok, but is 90mm not too high, or am I reading that wrong.
Old 15-08-09, 07:05 PM   #10
Razor
Or these
they say they're lower than the others, but no mention of the mount to the yoke, my risers are angled back and it helps with screen clearance.
SV650 bar mounts Jamesey SV Talk, Tuning & Tweaking 1 04-08-09 07:43 PM
Help Broken indicator mounts Jay1 SV Talk, Tuning & Tweaking 2 25-04-09 06:39 PM
front cylinder engine mounts kwak zzr SV Talk, Tuning & Tweaking 4 01-03-07 08:53 PM
Bike GPS mounts DeeJay Bikes - Talk & Issues 1 04-01-07 02:24 PM
Need one of mounts these now..what is it called? Anonymous Bikes - Talk & Issues 4 23-04-06 01:20 PM
