Old 19-08-09, 10:56 AM   #1
mr.anderson
mr.anderson's Avatar
Question IP CCTV and The Law?
I am looking to start rolling out an IP CCTV system across the Hotel I work in. In a random discussion yesterday, someone mentioned that IP CCTV footage was not submissible in court.
I cant see why this would be the case. Can anyone shed any light on this?
mr.anderson is offline   Reply With Quote
Old 19-08-09, 11:03 AM   #2
timwilky
timwilky's Avatar
Default Re: IP CCTV and The Law?
There is a lot of argument that many if not most CCTV installations fail to comply with the law, principally data protection act.
However, even if the installation was ruled to be in breach of the law, I could not see a judge refusing to accept a video showing who had plunged the carving knife between the shoulder blades of the chef.
Not Grumpy, opinionated.
Old 19-08-09, 11:03 AM   #3
SoulKiss
SoulKiss's Avatar
Generally speaking its down to how tamperable is the system.
Digital Systems are seen as "weak" in that way.
Old 19-08-09, 01:48 PM   #4
Baph
I'm sort of with tim on this.
However, forget about installation (that will only cause problems if an employee raises issues). Instead, concentrate on health & safety, and on access to images/operating licence requirements.
Fail on those two, and a judge will refuse it regardless of the claimed crime. That applies to non IP systems too.
Old 19-08-09, 02:57 PM   #5
mr.anderson
Thanks for the pointers gents.
Just spoke to an "Industry Expert" who has said that it is more to do with digitally recorded images than IP CCTV - of course to overcome this, one would need to go back to tapes or something horrible like that.
Seeing as we already use a central recorder to store 30 days of images onto a local HDD, we're in no different situation going IP.
Security around the stored data will be priority then (as normal).
Old 19-08-09, 03:26 PM   #6
jambo
jambo's Avatar
I was involved in running a community CCTV project for a while. The legal side of that was a bit of a headache, but then, we were filming public, rather than private spaces, which didn't help.
Most of the hurdles are data protection act related for private spaces as far as I'm aware.
Jambo
Old 19-08-09, 03:46 PM   #7
Neeja
Surely this is irrelevant and would never crop up in court. It should be obvious to everyone involved that the butler did it.
Old 19-08-09, 06:31 PM   #8
Spiderman
Where the hell am I?
Spiderman's Avatar
Mr A..... this website is where i was directed to for more info about the do's and dont's of CCTV installs and Data Protection.
http://www.ico.gov.uk/
HTH
Old 20-08-09, 10:30 AM   #9
-Ralph-
I'm doing some work around this with a city council whose city centre CCTV systems are all IP and digitally recorded, I know very little about the systems themselves, but am dealing with the environment and infrastructure where the images are stored back at the data centre. I know that in terms of comms, private links are used to each camera cluster as opposed to having data traversing the internet, this is where you are most likely to get "insubmissable in court".
You need to be able to demonstrate to the court that the integrity of that data could not have been compromised, through compliance with auditable procedures around security of that data
  • Access control over who has electroinc access, user accounts, two factor authentication, etc
  • Have the platform regularly pen tested and close any holes found that could allow unauthorised electronic access internally or externally (ie: Hackers)
  • Use robust encryption whenever the data leaves the authorities control, ie: tape backup stored offsite, traversing the internet, etc
  • Ensure physical security for the platform, ie: located in a caged area in a secured data centre, with controlled personnel access, cctv, etc.
Old 21-08-09, 11:39 AM   #10
mr.anderson
What sort of infratructure are you using to support this? What type of storage and what sort of volumes of data have you seen?
We will ultimately have 100 cameras throughout our building, all going over our internal network. I have forecasted a maximum of 3gb/camera/24hours on average based on movement activated recording and 2fps.
Home CCTV chasey Idle Banter 6 10-06-08 04:18 PM
Mobile CCTV moving? ljharmitt Bikes - Talk & Issues 7 01-06-08 01:46 AM
CCTV @ Home 600+ Idle Banter 18 03-10-06 07:36 AM
