Old 30-08-09, 11:58 PM   #1
racermx
Default Oil pressure problem, maybe.
I through a rod in my sv650 / 2001. I opened it up and replaced the crank, rods and bearings all OEM suzuki. Everything went together fine. It ran great for about 2 hours. I put about .5 extra of a qt. of oil in when I rebuilt it. I am not sure about happened but I am hearing a little knock at about 4000 rpm's. Idle and reving in nutural sounds good but when you ride it and get up in the rpm's it sound like a faint knock. I didn't replace the oil pump, I should of but
I 'm not sure if thats the problem. Any help would be very cool. First time on the site, thanks.
Old 31-08-09, 10:15 AM   #2
Default Re: Oil pressure problem, maybe.....
Bloody hell the crank and rods must have cost you. Over £1k?
Race or road?
Depends what caused it to throw the rod, if it was big end failure it could have put fine metal chips through oil pump. I would oil pressure test it.
Old 31-08-09, 11:51 AM   #3
racermx
Race or road?
It's a road bike and it did cost a lot. I cleaned very, very well. it was the big end that failed.
Old 31-08-09, 11:56 AM   #4
Maybe oil pump was damaged then. Both motors I have here with failed big ends have lots of metallic sludge in cases from bearing shells.
Ear Pressure irnbrumad Bikes - Talk & Issues 15 03-06-09 10:28 PM
Tyre Pressure evilexel SV Talk, Tuning & Tweaking 5 20-02-09 10:57 PM
Under pressure - again. HELP! krhall Idle Banter 127 03-11-08 09:52 PM
Help! Low oil pressure? gavinsky23 SV Talk, Tuning & Tweaking 7 06-03-08 06:40 PM
What's your tyre pressure? Diveboy SV Talk, Tuning & Tweaking 28 03-05-06 07:05 PM
