Good day Mates!
How can I disable the TOS? |
The sensor has two connections I think with a mercury switch or tilt switch inside.
Check with a meter across the two wires to check for a normally open or normally closed (more likely) continuity. If its normally closed then just remove the sensor and join the wires together on the loom. |
Will do... thank you
fuel sensor | noob-saibot | SV Talk, Tuning & Tweaking | 9 | 26-08-09 03:14 PM |
Speedo sensor. | phil24_7 | SV Talk, Tuning & Tweaking | 5 | 19-12-07 08:41 PM |
Speed Sensor for a K3. | creamerybutter | Stuff Wanted | 0 | 26-02-07 10:34 PM |
Help! Speedo Sensor | pingu | SV Talk, Tuning & Tweaking | 6 | 01-12-05 12:03 AM |
Coolant fan & Sensor | Tris | SV Talk, Tuning & Tweaking | 5 | 10-06-05 11:36 AM |
