Old 11-09-09, 07:21 AM   #1
Essex-Tacy
Default Lights - Headlight to be precise.
Hey SV'ers,
So have been riding my SV650 K2 for about a week now and LOVE IT!!!, but unfortunatly my Main beam doesnt seem to work right (Im not exactly sure what the specific terms are but here we go)
The smaller bulb works perfect comes on, doesnt exactly light up anything BUT it does come on, as for the main beam it will turn on when I press the Pass button, but if I turn it on properly at the switch, it doesnt turn on, so atm I cant ride in the dark (bad times), have checked the fuses they are all fine, have opened up the switch and everything looks fine and dandy everythign touches and connects as it should, so what else could it be?????
Old 11-09-09, 07:43 AM   #2
s7uyj
Default Re: LIGHTS!!!! Headlight to be precise.
could be a break in the wire somwhere in the loom, have a look where the wires look most stressed ie near the stem. only thing i can think of unfortunately! other than that, although it looks ok, the switch might just be dead
Old 11-09-09, 11:19 AM   #3
vardypeeps
Yep sounds like a broken wire to your dip beam.
Only thing is I'm not sure of the best places to look on the Pointy SV?
Old 11-09-09, 11:24 AM   #4
fastdruid
fastdruid's Avatar
Ok so main beam works, have you checked the bulb?
Have you tried lights on (RHS switch all the way across), High beam on (LHS switch)?
If that works then likely LHS switch or wiring to bulb, if that doesn't work then likely RHS switch or wiring.
Druid
Old 11-09-09, 11:46 AM   #5
Essex-Tacy
Cheers lads (or ladettes if the case maybe), once I get home I shall reinvestigate and see if I can find the cause of the bugger
Old 11-09-09, 01:17 PM   #6
Holdup
The pass button will activate the high beam, so your high beam is working fine, with the lights on try putting the high beam on at the main switch.
The bulbs on the SV are H4's which are twin fillament, it could be that both main beam filaments in the bulbs could of blown, take the bulbs out and have a quick look or if you have any spare h4 bulbs or know of any one with some spare laying around try switching them over.
Hopefully i have read your post right and that helps a little
Old 11-09-09, 01:19 PM   #7
ophic
ophic's Avatar
good cos its a K2 - curvy
Silver SV650SK3, Fuel exhaust
Old 11-09-09, 08:51 PM   #8
punyXpress
punyXpress's Avatar
Default Re: Lights - Headlight to be precise.
But is it S or naked?
Now: Street Triple R
Old 12-09-09, 02:12 PM   #9
I bet you an entire scottish pound that the switchgear plug block is broken... Nice easy fix to bypass it if it is though.
How often do you use your lights? AndyL Bikes - Talk & Issues 40 19-09-08 03:49 PM
Single headlight to dual headlight swap Jase22 Bikes - Talk & Issues 2 23-06-06 11:19 AM
headlight / parking lights - UPDATE lukemillar SV Talk, Tuning & Tweaking 12 13-06-06 07:43 PM
Headlight Mounting bracket, headlight vincerhodes Stuff Wanted 1 10-05-06 07:12 PM
Lights? Bikerz SV Talk, Tuning & Tweaking 12 16-05-05 06:21 PM
