Old 11-09-09, 05:42 PM   #1
endomeph13
Default Fork corrosion and seals.
ok the bike has come back from the mech's and he said i have some corrosion on the stanchion which may end up leaking fluid. is there anything i can do to fix the corrosion without having to buy a new stanchion or forks? my wallet is in tears right now. also if i had to get a new stanchion would it be more cost effective to buy some new forks instead? and if so which ones?
Old 11-09-09, 05:47 PM   #2
Dave20046
Dave20046's Avatar
Default Re: Slight problem.
You might be able to wire wool it or something so it's not as abrasive, post some pics
Old 11-09-09, 06:01 PM   #3
flymo
flymo's Avatar
Yeah, get yourself some of that green scouring pad from the kitchen. Very gently with some warm soapy water give it a scrub. Should remove most of the rust without damaging anything.
Afterwards give the stanchions a wipe with some WD40 or a lightly oiled rag.
Old 11-09-09, 06:05 PM   #4
endomeph13
i cant get a pic yet as my cam's got no battery but i'll do so tomorrow after i fit my new scorpion. i just want to go out on it as i havent had the bike for a good few months cos i had no cash to fix the problems it had. so after dinner a little cruise around south london should get me happy again just that corrosion thing will be in the back of my mind.
Old 11-09-09, 08:40 PM   #5
punyXpress
punyXpress's Avatar
Default Re: Fork corrosion and seals.
Fix the corrosion BEFORE going for that ride.
I know it's not such fun, but neither is forking ( sorry ) out for new seals.
It might just make the difference!
Now: Street Triple R
Can you repair front fork corrosion? robertjp SV Talk, Tuning & Tweaking 45 23-01-09 10:33 AM
Fork Corrosion duffbattye SV Talk, Tuning & Tweaking 8 19-07-06 04:30 PM
Fork corrosion Jelster SV Talk, Tuning & Tweaking 8 12-12-05 11:12 AM
fork corrosion kjames SV Talk, Tuning & Tweaking 7 09-11-05 12:01 AM
Front fork Corrosion Banus SV Talk, Tuning & Tweaking 4 18-03-05 08:23 PM
