Old 13-09-09, 08:44 PM   #1
Default Wanted - broken gear lever.
As above, a broken gear lever from any model SV from any year.
All I need is the rose joint, the condition of the rest of the lever is unimportant.
Old 13-09-09, 08:48 PM   #2
davepreston
Default Re: Wanted - broken gear lever.
no worries mate ive got a busted one here i'll post it to ya pm me details
Old 13-09-09, 08:58 PM   #3
Check out the service on SV650.org! Four minutes from asking and I have a positive response.
Thanks Dave, PM on it's way.
Old 13-09-09, 09:00 PM   #4
Nobbylad
Nobbylad's Avatar
I've got one too, let me know kidda!
Old 13-09-09, 09:01 PM   #5
So....em......why ??
Old 13-09-09, 09:14 PM   #6
davepreston
my guess some proper org bodging
Old 13-09-09, 09:41 PM   #7
Because I have to repair a bike with a gear lever that has a damaged rose joint, and ordinarily when one is unfortunate enough to break one in the more conventional manner, ie snapping one with a ground/motorcycle interface circumstance, said joint is very rarely damaged.
Old 13-09-09, 11:16 PM   #8
DavieSV
DavieSV's Avatar
I'm after one for a k4+.
One with only the toe peg broke off would be perfect.
Mine is a little bit too short. The peg is too far up my foot on up changes and I've not enough leverage on down changes.
John
DavieSV is offline   Reply With Quote
Old 17-09-09, 04:12 PM   #9
davepreston
posted today for ya bruv
Old 19-09-09, 01:19 PM   #10
Got it, fitted it.
A bit of grinding, bashing and welding later, the rose joint was removed from the broken curvy lever and pressed and welded into the, (otherwise), good SV1000 one.
It works!
Thanks Dave.
Replace broken gear lever? Rimer SV Talk, Tuning & Tweaking 14 19-10-12 10:21 PM
gear lever wanted 22 Stuff Wanted 2 08-02-08 02:45 PM
A broken Gear change lever (Mk1SV) Viney Stuff Wanted 2 19-07-07 02:04 PM
Broken Gear Lever ***Steve*** Bikes - Talk & Issues 11 04-06-06 10:43 PM
Gear lever wanted Moriarty Stuff Wanted 3 12-05-06 10:26 AM
