Old 15-09-09, 11:13 AM   #1
markehb
Unhappy MOT headlight failure, need help
I have a '02 Curvy import that's just failed its MOT due to the mainbeam headlight pointing too far to the left it seems. The headlight adjuster did not help this. I've not checked the haynes manual yet but I assume as it's an import the light's etc will be different from what's in the manual so I'm not sure how well I'll get on taking the front end to pieces.
Any advice/guidance in this area would be much appreciated.
Thanks
Old 15-09-09, 11:28 AM   #2
jambo
jambo's Avatar
Default Re: MOT headlight failure, need help
Hello, the only fix for this I'm aware of is to replace the headlight with a UK one. If someone has a UK light with a broken back (this is quite common accident damage) you can separate the front and back out in an oven and use your EU back with a UK front and UK reflectors (I did this with mine).
Jambo
Old 15-09-09, 12:00 PM   #3
warrenhewitt10
a mate of mine has an import curvy, the way its went through mots in the past is to black insulating tape over the lens cover so that beam shines correctly, it was the dealership he bought it from that showed him this and its passed its last mot without a problem
MOT failure dirtydog Bikes - Talk & Issues 26 26-04-09 12:16 PM
MOT Failure melody Idle Banter 33 24-02-09 03:06 PM
Failure Dicky Ticker The Essex Lounge 14 30-10-08 08:52 PM
Single headlight to dual headlight swap Jase22 Bikes - Talk & Issues 2 23-06-06 11:19 AM
Headlight Mounting bracket, headlight vincerhodes Stuff Wanted 1 10-05-06 07:12 PM
