Old 19-09-09, 05:44 PM   #1
Lucas
Default One cylinder cutting out
during a 30mins test run, one of the cylinder cutted out intermittently, along with the rev counter (does this mean the front or back cylinder?), sometimes it cuts out for seconds then fires again, sometimes the engine needs to be revved to get the cylinder firing.
anyone got a DIY check list to this issue?
cheers,
Old 19-09-09, 05:48 PM   #2
Default Re: One cylinder cutting out
Front pot.
Maybe loose battery lead or something liek that.
Old 20-09-09, 10:27 AM   #3
Lucas
Battery has good connection, I better check all wire connection leading to front pot and the rubber tube connections to the carbs. Any thing else I should look out for?
Old 20-09-09, 11:46 AM   #4
Spiderman
Where the hell am I?
Spiderman's Avatar
Checked the spark plugs mate?
Old 20-09-09, 12:04 PM   #5
maclovin
black and yellow wire (i think) going to right hand coil (as sat on bike) under tank happened to me exactly the same
Old 20-09-09, 04:35 PM   #6
diamond
My rear cylinder cuts out, in fact it doesn't fire at all at the moment.
Not sure why, I've bought a new lead to try
Old 20-09-09, 05:42 PM   #7
Lucas
yeah, me think the same, hope its just a lose connection
lucky we only got two cylinders, it would be twice the touble with IL4
cheers
lucas
Cutting Out FlyinCustard SV Talk, Tuning & Tweaking 44 09-05-09 03:16 PM
Cylinder cutting out? thedonal SV Talk, Tuning & Tweaking 15 12-02-07 07:57 PM
Cutting out.. MidgetMoose SV Talk, Tuning & Tweaking 4 25-11-06 06:22 PM
cutting out 01 sv650s SV Talk, Tuning & Tweaking 2 04-11-06 11:13 PM
Cutting out The Basket SV Talk, Tuning & Tweaking 1 19-03-06 08:46 PM
