Old 28-09-09, 10:18 AM   #1
robh539
Default advicewhen stripping forks?
Had my bike in the garage for some work on my forks, as i dont know how to suport the bike. Its a Y plate 650s 22,000 miles.
He changed the oil, and has put to much in, so really hard and to much about 2" / 2.5" of travel, (tie wrap test). Its going back into have this corrected. gret setup for a track were there are no potholes or sunken man hole covers lol
Tho he says i will prob end up having to replace the internals.
  1. How much travel should i expect ? more than i have i hope
  2. How do you all suport the bike when stripping the forks at home?
I wish to take it apart and see for myself.
thanks for your help in advance
Old 28-09-09, 10:35 AM   #2
fastdruid
fastdruid's Avatar
Default Re: advicewhen stripping forks?
1) I'd expect to see full movement on the road, as this shot shows of my VFR[1]
2) Supporting the bike is easy even without an ideal setup, couple of BFO blocks of wood under the engine and on the side stand will do not ideal and you have to be a bit careful but it will work.
Druid
[1] Ok so admittedly this is from one place where there is a rise and at mumble, mumble, mumbe mph it bottoms out
Old 28-09-09, 10:58 AM   #3
robh539
oh ok the trusted bfo blocks again, ok great ill have a hunt around then for some. ill have ago then,
wow, thats some movement, at the setup at the moment is so hard hit anythink lower/higher then 0.5" bang its like i have scaff poles for springs. But great when out on the lanes at speed.
thx druid
Old 28-09-09, 11:07 AM   #4
fastdruid
fastdruid's Avatar
The VFR is possibly a little extreme, shows more how I ride it than anything else but the idea is that you should *use* your suspension, if you're only using 2inches (out of IIRC 4) then you may as well not have 4 inches of travel, I'd expect in 'normal' use to be using 75-80% or so and occasionally to use all.
Druid
Old 28-09-09, 11:21 AM   #5
robh539
Yeah i agree ill let him take out some of the oil and see what comes back then take it from there. i was gonna asy to him i want 3/4 travel
Old 28-09-09, 05:19 PM   #6
Why would you have to replace the fork internals because a spastic can't RTFM?
Old 28-09-09, 05:30 PM   #7
My thoughts exactly.
You won't need to strip the forks, you'll only need to remove the top cap, empty the oil out and refill with the right amount.
Old 29-09-09, 12:11 PM   #8
robh539
lol, im going to get him to sort the oil level out, i will do the work myself from now on, and im not going to replace the anything as its not needed. T
he only reason why i didnt do it myself is my and couldnt work out the best way to support the bike and time.
Thanks to a big garage and some lifting slings i have it sorted.
Old 29-09-09, 02:56 PM   #9
Only internal you might want to replace is the spring. Stock are very soft.
I'm stripping tomorrow. phil24_7 Idle Banter 24 04-12-07 11:47 PM
Stripping a bike? MeridiaNx Bikes - Talk & Issues 29 18-11-07 09:07 PM
Stripping the bike thepyrofish SV Talk, Tuning & Tweaking 7 04-04-06 11:09 AM
Stripping off rubberduckofdeath Bikes - Talk & Issues 3 30-06-05 06:16 PM
