Old 26-10-09, 10:11 PM   #1
yankeedoodle
Default sv thou swingarm dimensions
hello guys.
im enjoying looking through the forum as always!
just wondered if someone could tell me the width of the sv 1000 swingarm where it goes into the frame. just trying to work out if it will fit other frames too.
thanks
Old 26-10-09, 10:19 PM   #2
Default Re: sv thou swingarm dimensions
Don't know right now, but I could have a measure if no-one else can help.
Old 26-10-09, 10:22 PM   #3
genesismike
hi, i ll try and measure mine tomorrow night if nobody posts up the sizes before then. Off to bed now ready for work.
Old 27-10-09, 09:21 PM   #4
yankeedoodle
thanks guys. that would be really great if you could
Matt
Old 29-10-09, 06:56 PM   #5
yankeedoodle
anyone?
Old 29-10-09, 11:58 PM   #6
xXBADGERXx
I`ll remind GenesissyMike in work tomorrow mate .
Old 30-10-09, 07:58 PM   #7
genesismike
Thanks for reminding me xXBODGERXx he he,
its a bit difficult to get in there properly to get an accurate measurement but i reckon the swingarm is approx 275mm wide at the pivot end (give or take a few mm). hard to get at it as the rear exhaust and the shock block decent access to measure it. believe its very similar to a gsxr 600 swing arm as the thou apparently shares a few suspension components with it. dont know what your planning on fitting one to but i think the pivot bolt is a different diameter to the sv 650. from an engineering point of view nothing is impossible, its a case of how much work you want to do to make it fit. good luck with whatever your planning ..... mike
How thick is the swingarm on a thou? Mark_h SV Talk, Tuning & Tweaking 5 10-03-09 12:20 AM
Bolt dimensions help please? Brettus SV Talk, Tuning & Tweaking 2 23-02-09 12:25 PM
SV1000 Dimensions Needsy SV Talk, Tuning & Tweaking 2 12-02-09 09:04 PM
Wheel dimensions. gixerboy1 SV Talk, Tuning & Tweaking 5 29-12-06 07:55 PM
SV650 dimensions.. SteveB SV Talk, Tuning & Tweaking 10 26-04-06 10:10 AM
