Old 31-10-09, 01:24 PM   #1
LK-SV
Default Radiator fan not working.
Done a quick search, and can't find anything ....
I don't normaly sit in traffice (filtering or other routes) ..... but just been out a bimble with my newby 125cc friend ...
Anyway ..... bike was gettting hot, but couldn't remember what temp. it kicks in ...... remember my old car used to go to 104degs ...... but got to 112degs before having to switch the engine off to cool !!!
So, I'ce checked the fuse .... seems ok ...... front raditor connector looks a little corroded, but looks good enough ...
Where do I look next ??...... (only got basic toolkit) ...
Thanks
Old 31-10-09, 01:35 PM   #2
Default Re: Radiatior fan not working !!!
Short the connector out and see if the fan comes on then
Old 31-10-09, 01:42 PM   #3
LK-SV
Will do ..... thanks ......... does the bike need to be hot??
Old 31-10-09, 01:43 PM   #4
No does not have to be running, just ignition on.
Old 31-10-09, 01:45 PM   #5
LK-SV
Cheers - thought not ..... but just checking ..... results in a mo ..
Old 31-10-09, 02:01 PM   #6
LK-SV
Yep - fan now working !!
New yellow sender thing then??
Difficult job??
Old 31-10-09, 02:08 PM   #7
First ask another pointy owner what temp their fan comes on at
Old 31-10-09, 02:20 PM   #8
LK-SV
Thanks .....
Anyone ???
Old 31-10-09, 02:42 PM   #9
tonny006
I think mine is about 106 degrees.
Where are you as i think i've got a switch in the garage.
Tony
Old 31-10-09, 04:02 PM   #10
LK-SV
Default Re: Radiatior fan not working.
I don't work too far from you .... Hampton Hill ....
Just to be sure..... its the yellow one at the bottom right hand corner of the radiator ....
I've got no idea what they cost !!
While you lot were working.... missyburd Photos 32 13-06-09 08:01 AM
Key not working wilky007 SV Talk, Tuning & Tweaking 12 29-12-08 01:27 PM
Speedo working, then not, then working??? krhall SV Talk, Tuning & Tweaking 25 24-04-08 11:35 AM
not working Again! wtdafk SV Talk, Tuning & Tweaking 18 10-01-07 05:29 PM
Working on the SV william t. SV Talk, Tuning & Tweaking 12 04-09-06 10:23 PM
