Old 09-11-09, 07:20 PM   #1
TonyS
Smile How much variation should there be in the chain tension?
Cleaning and oiling the chain after Sundays ride I found a tight spot where the chain had 2.5cm vertical travel, whereas the rest of the chain could be moved by 3.5cm.
Does this mean the chain needs replacing? Or is that within acceptable parameters?
Old 09-11-09, 07:25 PM   #2
fizzwheel
fizzwheel's Avatar
Default Re: How much variation should there be in the chain tension?
I cant remember off the top of my head. On the curvey theres a sticker on the standard chain guard that tells you what the chain should be adjusted to.
But a chain that has a tightspot on it, is more than likely nearing or reached the end of its life and I'd be inclined to replace it sooner than later.
IMHO.
Old 09-11-09, 07:32 PM   #3
Clean it thoroughly and check again. If there's a tight spot it's probably knackered.
Old 09-11-09, 07:35 PM   #4
TonyS
Smile Re: How much variation should there be in the chain tension?
Manual says chain should have 2-3cm vertical travel. But doesn't seem to give a figure for how much variation is acceptable as you move around the chain.
Old 09-11-09, 07:40 PM   #5
TonyS
What's the best stuff to use for chain cleaning? I've been using Wurth Chain and Brake Cleaner.
Old 09-11-09, 07:58 PM   #6
fizzwheel
fizzwheel's Avatar
Parafin and a toothbrush / paint brush.
Go to B & Q, into the gardening section, and look for a product called Parascene, they use it in greenhouse heaters, its parafin and much cheaper and just as effective as chain cleaner is.
Old 10-11-09, 01:33 PM   #7
Sally
Chain travel is 25-35 mm from furthest point upwards to furthest point downwards, measuered from the same place obviosuly.
I think. correct me YC if I am speaking shyt.
Old 10-11-09, 05:05 PM   #8
TonyS
Cheers.
Sounds like a good idea. I'm all for saving money at the moment.
Chain Tension Adjustment SV-net SV Talk, Tuning & Tweaking 3 03-07-09 09:24 PM
Chain tension - with a twist! aide_t Bikes - Talk & Issues 7 06-04-09 09:31 PM
Chain tension shakie1973 Bikes - Talk & Issues 1 18-02-09 09:00 AM
RE: Chain Tension G SV Talk, Tuning & Tweaking 37 26-02-08 10:55 AM
Chain tension pilot SV Talk, Tuning & Tweaking 7 01-10-07 05:12 PM
