Old 17-11-09, 01:24 PM   #1
SUPERSTARDJ01
Default Datatool digi gear
Hi,
Has anyone used/got one of these or the acuman version? which is better? and are they easy to fit?
Old 17-11-09, 01:43 PM   #2
rictus01
rictus01's Avatar
Default Re: Datatool digi gear
I've fitted both, prefer the acumen one, but currently I have a biketronix one here to fit at some point, got it off ebay for a lot less than either of the others.
Cheers Mark.
Old 17-11-09, 01:46 PM   #3
SoulKiss
SoulKiss's Avatar
I keep meaning to build a proper version of the one I designed....
Maybe if the SV was on the road I would find it easier to find the time...
Old 17-11-09, 02:55 PM   #4
SUPERSTARDJ01
http://cgi.ebay.co.uk/DATATOOL-DIGI-...item1e592903a7
£40
Old 17-11-09, 10:10 PM   #5
rictus01
rictus01's Avatar
Originally Posted by SUPERSTARDJ01 View Post
well that's £8 more than I paid and still 4 days to go, but hey up to you.
try looking at this one perhaps .
Cheers Mark.
Old 17-11-09, 11:34 PM   #6
merlin427
I've got a GIPro indicator on my Honda. Very easy to fit, simply plugs into a diagnostic socket. It works by comparing the RPM and speed pulses and converting to gear position and reacts very quickly, as soon as the clutch is in. The blurb on it indicates that some bikes ECU indicates gear position in which case these should react even quicker and not require the clutch to be out and the bike moving, can't comment if this is true though.
Digi Gear Indicator for Curvy. JPT650 SV Talk, Tuning & Tweaking 5 06-03-08 04:06 PM
Digi gear harness Gavin SV Talk, Tuning & Tweaking 2 28-12-07 06:22 PM
Anyone had a look at these before?(digi gear indicator) danf1234 SV Talk, Tuning & Tweaking 31 18-05-07 12:05 PM
Datatool DiGi Digital Gear Indicator... MitchC SV Talk, Tuning & Tweaking 15 03-06-05 02:53 AM
Digi Gear Indicator davy SV Talk, Tuning & Tweaking 0 13-03-05 08:57 AM
