Old 17-11-09, 01:24 PM   #1
Tim in Belgium
Question What kind of chain lube do you use offroad?
Off roaders, greenlaners and crossers, what kind of chain lube do you use off road?
And does it depend on the type of off roading, mud/sand/rock etc?
Does ordinary chain lube work ok?
Old 17-11-09, 01:26 PM   #2
speedplay
Default Re: What kind of chain lube do you use offroad?
I use a decent o ring chain and synthetic dry lube.
Just look after it as you would on your road bike.
Old 17-11-09, 09:38 PM   #3
Tim in Belgium
Dry lube could be a good call in the sand, do you reckon it's less sticky than traditional stuff and cause less sand to stick to the chain?
Old 17-11-09, 09:45 PM   #4
speedplay
Sand and mud will cause your chain and sprockets to wear out quicker (obviously).
I started using dry lube years ago on mountain bikes and just carried it onto the dirt bikes too.
The other thing I use is a chain wax, slightly thicker but better if the going gets really wet.
Old 18-11-09, 02:26 PM   #5
sunshine
I use some Putoline spray chain lube.
After every race take the chain off and clean the sprockets, chain and everything round there, we used to do it anyway.
Old 20-11-09, 03:44 AM   #6
MattCollins
A lot of 20W50 through an oiler. Terrain is all of the above. Cheers
Old 21-11-09, 08:38 PM   #7
Gear oil.
Old 21-11-09, 10:18 PM   #8
BILLY
old gear oil from the bike!!! why waist money on chain lube!! oh and clean and reoil after every ride!
Old 21-11-09, 10:45 PM   #9
sunshine
clumps of sand on the chain from used engine oil can cause the chain to slip when racing so you need something that wont stick the sand to chain is useful.
Old 21-11-09, 11:48 PM   #10
MattCollins
That is why I said a lot of 20W50. It is light enough to move (fling) and will take stuff that sticks with it.
Last edited by MattCollins; 23-11-09 at 05:39 AM. Reason: Added the quoted text to which I was specifically responding
Used oil for chain lube sunshine SV Talk, Tuning & Tweaking 26 27-09-09 09:39 PM
How much lube? (Chain lube!) AndyL SV Talk, Tuning & Tweaking 10 10-01-09 08:04 PM
Chain lube. furrybean Ancillaries 17 02-11-07 06:33 PM
Chain Lube fred_dillon SV Talk, Tuning & Tweaking 12 25-05-05 08:30 PM
Chain Lube splke Ancillaries 11 28-10-04 09:22 AM
