Old 20-11-09, 06:19 PM   #1
ian505050
Default sv2005s soft front end?
I have just sold my 2001 sv650s 20k and replaced it with a 2005 sv650s 7k
The front end seems to bang when i hit minor pot holes where as my 2001 model seemed to pass over the same bumps fine?
I have sat on the bike and rocked it forward and back to see if i can replicate the noise but all seems fine? No bang ect....
Old 20-11-09, 07:24 PM   #2
Bedhead
Default Re: sv2005s soft front end?
My K3 does that, sounds like knackered head bearings, apparantly they all do it.
Old 21-11-09, 05:58 AM   #3
MattCollins
Hydraulic lock.
Old 21-11-09, 06:14 AM   #4
rictus01
rictus01's Avatar
It's unlikely to be either of those above *. I'd suggest it's just the standard weak springs the SV comes fitted with, in all probabillity your previous SV had had the "oil & Spring" change already and your new one requires it.
*always possible of course, but SV's are know for there under sprung front ends as standard.
Cheers Mark.
Old 21-11-09, 09:53 AM   #5
Bedhead
It's the fork oil in the damper rods, but it really does sound like clunky bearings.
Old 21-11-09, 10:15 AM   #6
lee67
just turn up ur preload and it wont clunk!!..
Old 21-11-09, 11:14 AM   #7
Dave20046
Dave20046's Avatar
Is the clunking actually detrimental to handling?
Old 21-11-09, 10:11 PM   #8
MattCollins
Cheers Mark.
My '09 "clunked" from new with its 90kg rider. The rapid motion of the under sprung front would have contributed to hydraulic lock.
Springs will certainly help.
Old 21-11-09, 11:37 PM   #9
MattCollins
Yes. The clunk is caused by a lack of compliance in the suspension which may briefly overload the tyre and cause fork flex and vibration. It will generally unsettle the bike, lowering its limits on uneven surfaces. In the same way it also lowers braking limits as the front chatters, skips and skids. You may not always hear it clunking but the same mechanisms are at work.
Old 22-11-09, 03:42 PM   #10
Dave20046
Dave20046's Avatar
So what's the remedy? different forks? I've got harder springs in mine and it feels ok (much better than standard) and it isn't bottoming out but I still get the clunk every now and then.
Soft Forks. Biker_Billy Bikes - Talk & Issues 2 28-09-08 08:19 PM
front shocks are too soft Majahid SV Talk, Tuning & Tweaking 29 28-06-08 07:41 PM
Am I getting soft timwilky Pennine Massive 16 18-11-07 01:50 PM
Soft front brake fixed, ideas anyone? Baph SV Talk, Tuning & Tweaking 3 03-05-07 11:49 AM
Soft front? Reckless Rat SV Talk, Tuning & Tweaking 8 03-05-06 06:00 PM
