Old 23-11-09, 02:41 PM   #1
suzsv650
Default R6 charging problems.
2002 R6
Producing 11.45V at ~5k lights on or off makes no Difference
What ya recon?
Old 23-11-09, 02:45 PM   #2
the_lone_wolf
Captain Awesome
the_lone_wolf's Avatar
Default Re: Electromonics
What's the battery voltage with the ignition off?
(•_•)
( •_•)>⌐■-■
(⌐■_■)
Deal with it...
Old 23-11-09, 03:09 PM   #3
suzsv650
i THINK its about the same ~11V
Old 23-11-09, 03:17 PM   #4
the_lone_wolf
Captain Awesome
Sounds like what mine did...
Reg/Rec could be the culprit, but if your battery is showing 11V it's weakening - should be 12.6-12.8V for a standard "12V" battery with no load, a faulty reg/rec could be the cause of the weakening battery
Have you had any starting problems recently?
(•_•)
( •_•)>⌐■-■
(⌐■_■)
Deal with it...
Old 23-11-09, 03:28 PM   #5
suzsv650
ohhh yes plenty of times it will start about twice. you need to bump it after. Also if you run it with the lights youl be lucky for two starts.
I think it is Reg/Rec or Generator but im not sure which one...
Its a right pita, im stuck rideing a cbr 125 to work
Also replaced the battery recently (6 months ago)
Old 23-11-09, 03:33 PM   #6
the_lone_wolf
Captain Awesome
Do you have a multimeter?
If so then see what the resistance is between ground and the (three?) connectors from the generator - they should all be infinite
You can test the generator output but it's a bit involved, perhaps find someone with a working reg/rec they could lend you?
(•_•)
( •_•)>⌐■-■
(⌐■_■)
Deal with it...
Old 23-11-09, 04:15 PM   #7
suzsv650
Nope dont know anyone with the same bike. I will test the Generator tonight.
Thanks.
Old 23-11-09, 10:01 PM   #8
embee
embee's Avatar
This flow chart might be a useful reference doc.
Old 24-11-09, 08:33 AM   #9
suzsv650
Thanks. Reg/Recs are only ~£20 on ebay so im gona pick one up and give it a go
Charging Problems. rugbyguy91 SV Talk, Tuning & Tweaking 1 16-07-09 06:58 AM
Charging/battery problems turbominimagic SV Talk, Tuning & Tweaking 8 28-10-08 11:01 AM
Battery / Charging Problems JamesMio SV Talk, Tuning & Tweaking 20 02-10-08 01:21 PM
Charging - AGAIN Tris SV Talk, Tuning & Tweaking 7 15-04-08 04:15 PM
Charging Problems Ter SV Talk, Tuning & Tweaking 3 10-02-05 12:22 PM
