Old 02-12-09, 12:22 PM   #1
rob13
Default HD Camcorder techy question
I'm considering buying a HD Camcorder (Panasonic HDC-SD10 for any of those with knowledge) for a Xmas present.
The person who its going to has the Panasonic TV which can play it straight off the SD card which is all well and good but I need to know more about how to rip the video off the card onto disc. The laptop they have is about 6 years old, 1.8ghz Athlon 64 processor, they have a DVD writer built in but only 80gb HD memory.
In addition to this, they also have a Panasonic DVD player/recorder standalone attached to said TV (see the compatibility i'm seeing here?) however as DVD isnt HD, I'm trying to think of a way to get the video off the SD card without having to wait days for it to process on the old laptop.
Does anyone else have a HD camcorder which they use without processing the results on the PC?
Old 02-12-09, 12:35 PM   #2
The Guru
Default Re: HD Camcorder techy question
You really need minimum of Dual Core, anything less and its jumpy.
Not sure about not using PC.
I've got HDC-SD9
Old 02-12-09, 12:37 PM   #3
wyrdness
Couldn't you plug the camcorder straight into their dvd recorder. According to the specs, the camcorder has component (high quality) and composite (low quality) connections. The dvd recorder should certainly have a composite input.
Old 02-12-09, 12:37 PM   #4
wyrdness
I've got HDC-SD9
No, it won't be jumpy, just slow to encode the video to DVD.
Old 02-12-09, 01:27 PM   #5
The Guru
Im talking about playback through the PC for editing etc. Its jumpy.
Old 02-12-09, 04:16 PM   #6
AndyL
Correct, I have an HD camcorder in fact it may even be the model in the OP (but i cant remember for sure), however the video playback on my PC (P9600 2.66GHz core2duo, GTX260M) still jumps about once every 3 seconds (@1680x1050 resolution). However once encoded to blu-ray and played back on my blu-ray player everything looks great and obviously it doesnt jump at all. If you want seemlees playback to a PC then you either need a very fast core2duo ~3.0 GHz or a Quad core to be save.
Old 03-12-09, 10:52 PM   #7
rob13
Excellent thanks for the assistance folks. I guess until he updates his tech, then recording to the DVD recorder will be perfectly reasonable.
HD for futureproofing, as at the moment, the DVD will only pick up SD.
I know all about trying to run Hi-Def stuff through that laptop as I've got the same. Its bloody rubbish even trying to just watch HQ Youtube stuff. Must save up for a new one..
Quick simple techy question about brakes monkey Bikes - Talk & Issues 5 23-01-09 03:50 PM
another techy one Wideboy Idle Banter 4 04-05-08 04:35 PM
Computer question (camcorder input) Chris V Idle Banter 3 24-03-06 07:21 PM
For all you IT techy lot... Sid Squid Idle Banter 9 02-02-06 12:55 PM
Which Camcorder sevy SV Talk, Tuning & Tweaking 2 11-07-03 08:45 AM
