Old 05-12-09, 10:05 AM   #1
Moojuicepez
Default Brake pads
hi all,
just scrolling through the FleaBay for servicing kits and such like as im about to hit 7500 mile and its never been serviced other than me changing oil and maintaning the chain.
are these any good?
http://cgi.ebay.co.uk/Full-Set-Brake...item3ef729fa14
Cheers for any help
Perry
Old 05-12-09, 10:15 AM   #2
rowdy
rowdy's Avatar
Default Re: Brake pads
I've used them before, thought they were alright. Better than stock brake pads imo.
Old 05-12-09, 10:21 AM   #3
rowdy
rowdy's Avatar
And another thing, have you had the bike from new and not serviced it?
If this is the case then you will have fun removing the pad retaining pins because Suzuki don't grease/copper slip them so they stick. When mine were first changed I couldn't get it to budge and had to take the bike to a spanner monkey and pay for the pads to be fitted. The mechanic tried heating it up but ended up having to cut the pin and then weld a nut on it so he could remove it, cost me a bloody fortune in the end. Haven't had a problem ever since as I now copper slip the pins.
Old 05-12-09, 10:35 AM   #4
Moojuicepez
1st owner had it from new and i beleive he had it serviced? hed only done 1300 in 3 years. ive had it for nearly 6 months and im one silly milage haha
my dad used to build plane engines, and has alot of knowledge with mechanics etc so i think i should be okay.
Cheers for the info.
should i be looking for certain things with servicing kits?
Old 05-12-09, 10:43 AM   #5
rowdy
rowdy's Avatar
Oil, oil filter and spark plugs should cover what you want in a service kit, only other stuff to look for at that mileage is check all your nuts and bolts are tightened correctly, brake fluid and coolant levels are ok etc. . that sort of thang.
Old 05-12-09, 10:56 AM   #6
Moojuicepez
okay cheers dude.
ill get buying
Old 05-12-09, 11:33 AM   #7
LK-SV
Your dad used to build plane engines, so knows about Suzuki SV motorbike brakes ??
A friend of mine works in a false teeth factory*, but I wouldn't have him do me a filling !!!
Only jesting with you mate .... but made me chuckle !!
*might not be true
Old 05-12-09, 11:58 AM   #8
Holdup
You might not even need pads yet tbh, whip them out first before spending your cash
Old 05-12-09, 12:50 PM   #9
steveg
steveg's Avatar
Have used Goldfren in the past , great pads at a great price.
Also bought off ebay
Rear pads seem to last about 18k a set
Cheers Steveg
ex - red sv650s 06 reg
Now Triumph sprint 1050 ABS 05 Reg
AKA Papa Smurf
steveg is offline   Reply With Quote
Old 05-12-09, 10:14 PM   #10
5hort5
Just worth noting that if you ordered your pads from wemoto you'd get the same ones as those.
5hort5 is offline   Reply With Quote
SV Racing Parts, GSXR Brake Caliper Adapter Brackets, & Galfer SS Brake Lines & Pads sv-racing-parts SV Talk, Tuning & Tweaking 42 15-09-11 10:27 PM
Brake Pads zigrat SV Talk, Tuning & Tweaking 12 03-07-09 08:12 PM
Brake Pads trevrobwhite Hardware 10 18-04-08 01:21 PM
which brake pads hovis Bikes - Talk & Issues 18 18-04-08 11:27 AM
EBC Pro-Lite brake discs and Goodridge GH brake pads r4ce_e3nd For Sale - SV's and SV related items 7 14-04-07 07:37 PM
