Old 11-12-09, 06:55 PM   #1
stonemason
Default fuel system
new member but been on bikes since moses parted the red sea but i wud be interested to know wot the inline fuel component is on the right side frame rail as it looks as if it does the same job as the fuel tap fuel
Old 11-12-09, 08:16 PM   #2
fastdruid
fastdruid's Avatar
Default Re: fuel system
Curvy or pointy?
If it's a curvy[1] its a fuel pump.
Druid
[1] 99-02.
Old 11-12-09, 08:18 PM   #3
Alpinestarhero
Just incase you are looking for a fuel tap on the SV, there isnt one It'll just start blinking an orang elight at you when you have used 13 litres of fuel, and when you have a litre left the orange light will stay on. At which point you panic and pray there is a petrol station in the next 9-11 miles
Old 11-12-09, 08:22 PM   #4
Listen to the welsh one, it is vacuum operated fuel pump (I think because carbs are higher than low point of tank). There is vacuum op petcock on the tank too.
Old 11-12-09, 08:22 PM   #5
thedonal
Or that you have not used up your 5 free breakdown calls this year.
Fuel system problem metalmonkey SV Talk, Tuning & Tweaking 10 15-09-08 07:49 PM
ABS system Dutchman SV Talk, Tuning & Tweaking 4 29-06-08 05:17 PM
Fuel System Issue IrishGirl SV Talk, Tuning & Tweaking 4 05-10-07 09:35 AM
Akrapovic full system or yoshi full system ? ? ? hall13uk Exhausts 40 15-08-07 11:44 PM
Replacement fuel light / fuel tap riktherider SV Talk, Tuning & Tweaking 7 14-05-07 06:41 PM
