Old 17-12-09, 01:46 PM   #1
beabert
Default Stoppping the damper rod rotating.
Time for a oil seal change.
Tried hitting broom stick inside, wont hold it, spring tension wont hold it. I cant see how im gonna undo this sodding bolt lol.
Old 17-12-09, 01:49 PM   #2
skeetly
skeetly's Avatar
Default Re: Stoppping the damper rod rotating.
Take it to a garage.
Take your broom handle.
Ask very nicely to be alone for a minute with their ratttle gun.
skeetly is offline   Reply With Quote
Old 17-12-09, 01:50 PM   #3
Rattle gun does trick. If not then take other side apart so you can see what tool you need to get into it properly. I think it's a big hex.
Old 17-12-09, 01:54 PM   #4
beabert
Ok, good ideal ill try the other to get some perspective.
yep its a hex, i think ill try the other fork now, give up on the right one lol
Ill give myself to the end of the day then hit the shop, or buy a compressor and gun lol
Old 17-12-09, 02:53 PM   #5
beabert
Second one took two minutes, much easier than i thought it was going to be.
Now to hatch a plan.
Old 19-12-09, 12:52 PM   #6
beabert
This is ****ing me off, sledge hammer and hand impact driver, nothing. The broom is in a sorry state.
It seems to be a common trend on this bike, everything is stuck
Next idea is fill up with penetrating oil over night.
Old 19-12-09, 01:27 PM   #7
beabert
On the way to the pentrating oil shop i had an idea and doubled back home, It worked
Old 19-12-09, 01:59 PM   #8
SV650Racer
They can be a right sod to get undone your not alone and its not just on the SV650!.
wheel spin thing (for rotating wheel) Corf SV Talk, Tuning & Tweaking 19 19-01-09 10:41 AM
do you get the damper rods out? charlie13 SV Talk, Tuning & Tweaking 11 28-08-08 12:40 PM
Mounting OEM damper pilot SV Talk, Tuning & Tweaking 2 18-09-07 10:56 PM
What damper is THIS? pilot SV Talk, Tuning & Tweaking 6 30-08-07 09:12 PM
damper help me hera Photos 6 05-11-06 03:38 PM
