Old 27-12-09, 09:31 PM   #1
scottjames
Default 07 bandit indicator problem.
After buying some after Market led indicators for the front and keeping the originals on the back. They all work at the right rate when Turning the alarm on and off but when you indicate they flash fast. I got some bits to plug in line with the indicators which I was told should slow them down to the correct rate. Obvi they don't work.
Where should I start?
Scott
Old 27-12-09, 09:33 PM   #2
Default Re: 07 bandit indicator problem.
They don't plug in line - they go in parallel.
Old 27-12-09, 10:03 PM   #3
scottjames
Ok, I thought they went in mine as they have plugs each end a
which all lines up etc?
Old 27-12-09, 11:21 PM   #4
A new variety I don't think I've seen - do they have four wires all tolled?
Old 28-12-09, 11:30 AM   #5
scottjames
They do have four wires and are color coded for the indicators. I've noticed tht the online bit which is meant to slow them is rated at 10w. The bikes relay for the indicators is rare at 21w. Would this make any diference?
Old 28-12-09, 01:47 PM   #6
scottjames
Indicator problem blackrat SV Talk, Tuning & Tweaking 6 08-09-08 05:28 PM
Bandit indicator lenses Endellion SV Talk, Tuning & Tweaking 0 26-07-08 01:23 PM
Indicator Problem Side MS SV Talk, Tuning & Tweaking 23 26-05-08 07:11 PM
CLEAR indicator covers wanted (SV650/1000, Bandit, DRZ, GSX-R) ... lucky strike Stuff Wanted 10 14-02-08 10:25 PM
Mystery indicator problem sgorio SV Talk, Tuning & Tweaking 0 30-07-06 09:45 AM
