Old 05-01-10, 06:07 PM   #1
hardhat_harry
Default GSXR Head bearings
Hi all,
Just got my GSXR600 front end and ordered the "special TWF" top head bearing for the curvy swap but I noticed that the GSXR lower head bearing is a roller bearing and the special bearing is a taper bearing. Should the lower bearing be a taper as well? Will the different bearings cause an issue?
Old 05-01-10, 06:18 PM   #2
fastdruid
fastdruid's Avatar
Default Re: GSXR Head bearings
No but if you are worried just get a single roller lower bearing such as
http://www.patternparts.net/suzuki/s...604.ppt-325505
Druid
Old 05-01-10, 10:03 PM   #3
Depends what lower is in your frame. I would replace it while it is in bits.
Old 06-01-10, 11:36 PM   #4
Yeah, worth doing while it's apart on general principles. The operating loads can be a bit different, but then, the same can be true of 2 different roller bearings too so it's probably not worth getting too worked up over that.
Old 06-01-10, 11:59 PM   #5
i've got a taper top (TWF one) and OEM ball bottom one. Have had for many thousands of miles with no trouble.
Fitting steering head bearings? SVGeorge SV Talk, Tuning & Tweaking 10 06-09-10 03:18 PM
Head Race bearings Stu Bikes - Talk & Issues 4 13-11-08 01:14 PM
Busted Head Bearings? Torn-Thorax SV Talk, Tuning & Tweaking 5 01-06-07 09:18 PM
Head stock bearings Davies SV Talk, Tuning & Tweaking 8 10-03-06 11:16 AM
Steering Head Bearings rjh SV Talk, Tuning & Tweaking 3 13-10-04 02:12 PM
