Old 29-01-10, 01:47 PM   #1
MrTom
Default Tube to extend front carb nipple
I intend to have the radiator off the bike this weekend and would like to take the opportunity to attach some tubing to the the front carb for future balancing.
Problem is, I don't know what sort/size of tube to get and where I would go for such a thing.
Thanks in advance
Old 29-01-10, 01:47 PM   #2
Default Re: Tube to extend front carb nipple
Same stuff as comes on carb balancers, motor factors? Vacuum pipe will work but the stuff for cars tends to be massive.
Old 29-01-10, 01:56 PM   #3
fastdruid
fastdruid's Avatar
I've used washer tubing before.
Of course I can't recall of the top of my head what size the nipple is for the SV.
Druid
Old 29-01-10, 02:12 PM   #4
Taipan
Taipan's Avatar
I might have this wrong but i'm sure I read somewhere about someone using the tube from a scottoiler bottle?
Old 30-01-10, 04:45 PM   #5
MrTom
Ok, thanks. Im gonna have the bike 'open' for a while so will experiment with what fits.
Old 30-01-10, 05:16 PM   #6
Alpinestarhero
*giggle*
"nipple"
*giggle*
Old 30-01-10, 05:31 PM   #7
boot
Pretty certain it's 6mm tubing you need. I did mine with tube sold at a local hardware store. Plugged the end with a plastic numberplate screw, which works a treat.
Old 24-02-10, 12:22 PM   #8
Grant66
Grant66's Avatar
Can somebody confirm that 6mm is the correct size? Calling in at B&Q on way home for other DIY related stuff thought I'd get some tubing whilst I'm there.
Grant66 is offline   Reply With Quote
Old 24-02-10, 01:27 PM   #9
MrTom
I eventually used the larger of the two sizes of clear windscreen washer tube that halfords have. I had to soften it in hot water and stretch the end with a screw driver a little though.
Old 24-02-10, 01:32 PM   #10
Easy trick for tubing, put it on floor and bash it repeatedly with a hammer. The flexing warms the rubber and you don't have to boil the kettle. Once it is on, it is not moving easily though.
PVC tube for sorting front preload stuballs SV Talk, Tuning & Tweaking 5 12-11-09 12:34 PM
excess fuel from front carb needle jet at tickover? charlie13 SV Talk, Tuning & Tweaking 6 11-07-09 10:55 PM
Front brake reservoir & connecting tube Raf Stuff Wanted 0 08-08-07 02:02 PM
FYI - Suzuki extend 0% finance deal SV650Racer SV Talk, Tuning & Tweaking 8 05-07-07 12:57 PM
Front Carb ... sprocket Stuff Wanted 6 16-04-06 04:47 PM
