Old 31-01-10, 10:13 PM   #1
bingothebike
Default Battery bolts
I tried fitting a battery charger harness recently but when the spade connectors were fitted under the battery bolts, there was not enough thread to screw the bolts in. Looks like i need some slightly longer ones.
Anyone know the spec or where to get some new ones?
Cheers all.
Old 31-01-10, 10:21 PM   #2
tigersaw
tigersaw's Avatar
Default Re: Battery bolts
Take the washer off if there is one.
Get a screwdriver behind the nut and push tight against the inside of the battery stud when threading the bolt.
Old 31-01-10, 11:38 PM   #3
5hort5
stick a blob of blue tac under them to push the nuts up - screw the bolts in and remove the blue tack. I do it each time tbh
5hort5 is offline   Reply With Quote
Old 01-02-10, 09:31 AM   #4
sz1
if they are too short try these guy's might be able to help http://forums.sv650.org/newreply.php...te=1&p=2167004
or take your existing ones down to your local d.i.yshop get some same size and just cut to desired length.
Old 01-02-10, 10:26 AM   #5
timwilky
timwilky's Avatar
From memory (at work so cannot check, I think they are an M6. Available anywhere.
I like the idea of a bit of blue tack under the nuts to push them up.
Not Grumpy, opinionated.
Old 01-02-10, 08:41 PM   #6
skyline
If it helps I used a jaycloth when putting my charger connector on.
I tore a strip off the cloth and folded it, then placed the strip in the battery terminal with the end of the strip sticking out, then balanced the nut on top.
Get the screw and harness on, and the nut should be raised enough to catch on the screw.
When the screw is tightened, grab the end of the strip sticking out of the battery and pull the strip out.
HTH...
Old 01-02-10, 08:44 PM   #7
+1 now why didn't I think of that
battery terminal bolts Cam_73 SV Talk, Tuning & Tweaking 2 08-12-09 07:59 PM
Optimate battery charger drains the battery flymo Bikes - Talk & Issues 10 10-06-09 10:41 AM
Battery Terminal Bolts JediGoat SV Talk, Tuning & Tweaking 6 12-05-08 12:03 PM
Long bolts? Short bolts? andyaikido SV Talk, Tuning & Tweaking 6 25-01-06 04:53 PM
Battery/Starting problem - new battery hasnt fixed it! Aaron SV Talk, Tuning & Tweaking 13 24-01-05 05:21 PM
